anyone have a how-to on taking out a y8 tranny
i have a clutch kit and dont want to pay a place to do it and plus my car is just sitting there casue i got my license is suspended till june 24 so i figure i can have the tranny taken out and pu back in by then but i just wanted to know if anyone knew any sites or anything that could show me what bolts to remove and i know i have to remove the motor mount but that is about it
Modified by nitrousFed97ek at 7:00 PM 5/14/2003
Modified by nitrousFed97ek at 7:09 PM 5/14/2003
ummm a helms manual would be all you need to do this!....other than that i dunno any sites that would be that great with just an instructional on replacing a clutch?
should be 3 bolts across the top of the tranny. (17mm i believe) one is more to the front of the engine than top, but its listed as top. Then, there are 2 on the back going through the rear mount. (19mm) then assuming there is a scatter shield thingy, that needs to come off along with the stiffener's (big bracket things that you'll see goin from the block to the tranny.) those are all like 14mm or 10mm i believe. Then the long bolt through the starter (shoudl be the left bolt) i forget the size of it. and that should be all you need unbolt. then just take it off.
make sure you support your engine with a jack or old wheels/tires- otherwise, it's going to be falling down...lol. You'll need to remove the bolt from the rear mount as well.
Also, use a jack or transmission jack to guide the tranny of the engine
Putting the Spoons to good use...lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nitrousFed97ek »</TD></TR><TR><TD CLASS="quote">well i am off to go get the helms
what else do you need to know??
Unseen Racer
33
Aug 25, 2009 12:35 AM
