now what?
Old May 14, 2003 | 06:42 AM
tpr's Avatar
tpr
Default help with ZC swap
I am installing a twin cam ZC engine in a 1990 SI Civic and have the car running now, but with problems. The supplier sent a three sensor distributor (possibly related to the 1999 Civic) with the engine instead of the usual two sensor distributor and the cylinder position sensor on the exhaust cam. Now I get a dtc #4 (ckp signal, crank sensor) and the engine quits at 3200 rpm. I have tested and found distinctive signals (with Vantage) for ckp, tdc and cmp signal at their proper location at the SI computer and am convinced I have the correct signal and the proper location indicating I hooked the distributor up correctly. What have I done wrong? Is this distributor not compatible?
Old May 14, 2003 | 07:13 AM
tpr's Avatar
tpr
Default Re: help with ZC swap (tpr)
is it working?
Old May 14, 2003 | 08:38 AM
REDBARON's Avatar
Why don't you just replace the distributor with one from a 89 Integra? That should solve your problems.
Old May 14, 2003 | 08:59 AM
DJ_SaNdOz's Avatar
Default Re: help with ZC swap (REDBARON)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by REDBARON &raquo;</TD></TR><TR><TD CLASS="quote">Why don't you just replace the distributor with one from a 89 Integra? That should solve your problems.</TD></TR></TABLE>
these may help:
http://www.geocities.com/AGGRE...E.HTM
http://www.thezcr.com/html/zcbook.php
There is another site that shows how to rewire the dizzy- let me look & I'll post back.
Old May 14, 2003 | 11:03 AM
DJ_SaNdOz's Avatar
Default Re: help with ZC swap (DJ_SaNdOz)
OK mang- this should be enough info between my last post & this.........
http://www.hasport.com/Tech/In...C.htm
http://www.geocities.com/civiczc/zcinfo.html
http://www.geocities.com/chipman_13/zc.html
http://www.quickhonda.net/zc3.htm
Yuta
Oct 14, 2018 06:03 PM
tommygunn
Jul 14, 2010 04:53 AM
alexsracing
Nov 20, 2007 10:17 AM
ECICivic
Apr 3, 2005 04:51 PM
ScottEK
12
Oct 6, 2002 07:54 PM
