JDM Integra Type R headlight question
From: where having a nice car is a crime..., vA, USA
hey guys i need some help!! i just got my JDM integra Type R headlights..now i have heard that they sell the hiring connector for the back of the headlights to run the high beams and gold fog light and cruising light..how much is that? did anyone just make their own harness?? also i heard that i have to order a different corner bulb..is that true?? any one know? thank
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmspoonitr »</TD></TR><TR><TD CLASS="quote">Yes you need a new corner bulb. And the wiring came with my lights.</TD></TR></TABLE>
were do u get the new corner bulb, or is it the grey harness you have to get.
well guys i just finished up the install of the whole conversion...still having trouble with the corner bulb fitting in there and i need to get hood pins and the 90-93 integra hood cable...any suggestions for the wiring??i need help
u can custom make a harness w/ electircal tape and wire loom... as for the corners, just use ur factory ones... u have to cut some of the tabs... it will be really tight with the rubber... so go to hobby lobby or crafts store and buy some "fun foam"- thin foam sheets... and cut out a gasket... they work really well, nice tight fit...
as far as the corners...yeah i was having that idea as far as cutting the holder, cross my mind...i guess i will have to customize... how does everyone run there set up? right now i have the corners and fogs hooked up,and then the low beam comes on.. i was goin to run the fog,crusing light,and low beam....then just the high...or i might just run a switch to the fogs....
what is this i hear about a fatory fog light harness on our carS?? n e one know??can i use that on my jdm headlights for the gold fogs???
civtrx
Nov 15, 2005 01:06 PM
itsm3paul
11
Mar 16, 2004 05:29 AM
