my car is not running i need help!!!!
Old May 14, 2003 | 06:16 AM
0 0 0's Avatar
Default my car is not running i need help!!!!
ok heres the story....
my friend put a 1st gen b16 in his 92 hatch,at first the car idled erratic that was fixed....second the car wa revving at like two grand,that was fixed then i got the car running but for some reason it would only go to like what seemed 3 or 4 grand and hits what seems to be a rev limiter...i was throwing a throttle position sensor code and a crankshaft position sensor which is in the distributer so i tried a different dist but it was one for a sohc v-tec dist but it wasnt lining up so i put my old one back on then i go to crank it up and now it wont start at all it just turns over..so i went from a semi-running car to a completely non-running car....please help me before i light the car on fire!!!!!
Old May 14, 2003 | 06:31 AM
Quik Chris's Avatar
Default Re: my car is not running i need help!!!! (vxHATCHATTACK)
Sounds like you might have your TPS sensor and MAP sensor switched, then in addition to that you need a new distributor.
Old May 14, 2003 | 07:02 AM
0 0 0's Avatar
tried that didnt work
Old May 14, 2003 | 10:49 AM
josups's Avatar
any help would be greatly appreciated
titosek4
19
Aug 18, 2009 06:39 PM
v8killa121
Sep 26, 2005 12:49 PM
acurateggy93
Aug 15, 2005 10:36 PM
fe519
Jan 1, 2003 10:09 PM
stizzit
Jan 24, 2002 08:30 AM
