GSR vtec whooes.. HELP me
Old May 13, 2003 | 08:31 PM
92HB_HB's Avatar
Default GSR vtec whooes.. HELP me
help, my gsr vtec feels like nothing.. I can't seem to get the darn thing working right.. i know the wires are correct because i check them over many times and there are no CEL's .. i believe its a vacuum issue because when the vacuum hose is plugged to the actuator that controls the 2ndary butterflies when idling, it opens them.. is this right? or is it wrong?? should there be vacuum present at that hose during idle? or should it be absent?? I wish i had another gsr around so i can compare , but unfortunately, finding someone is pretty hard.. arrrghh..
also, not only can i not feel the vtec, i can barely hear it from the engine.. I do hear a notable change in the exhaust note though when i'm up in the revs, but the power difference is pretty much inexistant.. I dont even feel the slighest pull in the upper rev range as compared to the lower rev range.. what gives??
Old May 13, 2003 | 08:46 PM
tilt's Avatar
Default Re: GSR vtec whooes.. HELP me (92HB_HB)
vtec crossover should be a quiet and smooth transition. as long as it keeps pulling then you are fine.
Old May 13, 2003 | 08:52 PM
iH8RICERZ's Avatar
Default Re: GSR vtec whooes.. HELP me (tilt)
if you open up the air box for the stock intake..and take it up in vtec, you'll be able to hear vtec nice a loud. even if you have no mods on your car
Rishiras
Apr 22, 2007 04:47 PM
JdmFront619
Dec 23, 2003 10:48 PM
92HB_HB
May 13, 2003 05:56 AM
White S2k
11
Oct 30, 2002 11:07 PM
