question about my intake manifold holes....
Old May 13, 2003 | 06:58 PM
SymphonyX's Avatar
Default question about my intake manifold holes....
i just drop off my car at the shop to finally finsh the whole entire motor build up.
since i am port and polishing my head, should i port the intake manifold?? (skunk 2 manifold)
this is what i am doing to my car. (the block is built already with ctr over bored pistons and knife edge crank). what i am getting done now is
skunk 2 stage 2 cams, skunk2 cams gears, skunk2 valves,springs and retainers, and 68mm str throttle bodie. mugen head gasket
so, should i port the manifold or the head will do?????????
Old May 13, 2003 | 08:12 PM
SymphonyX's Avatar
Default Re: question about my intake manifold holes.... (SymphonyX)
so, should i???? i nee to tell my friend tomorrow. i want to know is it worth doing it??
Old May 13, 2003 | 08:21 PM
SpoonFedHatch's Avatar
as long as the head is port-matched to your manifol's specs, i wouldnt go through the trouble of porting the manifold.....and remember, INTAKE SIDE of porting should be textured, not polished ......good luck on the buildup
2k.civic.si
17
May 12, 2010 08:59 AM
airmaxbri
Feb 26, 2010 09:05 AM
99B19CEK
May 21, 2009 04:39 AM
JBBNJ609
52
Nov 19, 2004 06:42 PM
-Whitey-
10
Dec 27, 2002 12:30 PM
