drive shafts for CRX with b16a?
you hsould be able to use any b series axels off of an integra or a civic si(non-ABS of course), but someone please correct me if i am wrong.
If you are using a 90-91 teg int shaft (itll say sk7 on the bracket where it meets drivers side axle) then use 90-91 teg axles. Otherwise you can use a 90-91 teg axle on the pass. side, but will have to get a custom axle if using the jap int shaft. Hope this helps -Josh-
Check the HaSport Axle Page They have the low down on what to use depending on what intermediate shaft you're using.
http://www.hasport.com
aojtin
Mar 6, 2009 12:26 PM
tune-ups
Jun 24, 2004 10:04 AM
