how to put in clock?
pull out the center vents, slide a butterknife on both sides, carefully pry them out, theres 2 metal clips, compress the clips and the entire housing comes out, turn it over, there are 2 phillips screws holding the block off plate in. Unscrew them then just screw in your clock, there should be a harness tucked away back there for it. if there isnt you'll have to wire up the clock somehow.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WuShu »</TD></TR><TR><TD CLASS="quote">there should be a harness tucked away back there for it. if there isnt you'll have to wire up the clock somehow.</TD></TR></TABLE>
Yup, it'll be back there. Also when you go to take the vents off if theyve never been taken off before, even if you get the clips theres a foam type sealant that youll have to pull pretty hard and rip it to get the vents off. But after the first time the clips hold it.
Drew96EJ
Sep 27, 2003 03:20 PM
