What type(temp) of spark plugs to use on JRSC'd engine?
Old May 13, 2003 | 05:42 PM
Blue-Civic-Hybrid's Avatar
Loved
Default What type(temp) of spark plugs to use on JRSC'd engine?
I just finished the install of my JSRC on my B18C1, hopefully on wednesday my Hondata S100 w/boost will be installed at AEBS. I am just wondering if I should change my plugs prior to tuning, this is the first boosted motor i have ever owned and I would like to gain some insight on which plugs you supercharged people are using for daily driving and what you have found work best. I am currently running stock 6psi boost, with a Mugen thermostat, Mugen fan switch, FLuidyne Integra radiator, Magnecor plug wires...any info or opinions will be appreciated...
Old May 13, 2003 | 05:51 PM
CRVRX's Avatar
Default Re: What type(temp) of spark plugs to use on JRSC'd engine? (Blue-Civic-Hybrid)
I always use BKR7ES NGKs , They work well and are cheap.
I have also use ZEX plugs which I have had good luck with also.
Old May 13, 2003 | 06:05 PM
keebler65's Avatar
Default Re: What type(temp) of spark plugs to use on JRSC'd engine? (CRVRX)
thats what i'm going to be using as well. it sounds like they are most popular for this application. also if you dont know, they typical gap is .35-.38 from what i've read everywhere.
Old May 13, 2003 | 07:06 PM
jabroni95gsr's Avatar
Default Re: What type(temp) of spark plugs to use on JRSC'd engine? (keebler65)
believe it or not, i'm still running the platinum plugs and they work fine. However, i intend on changing them to non-platinum, but since you will be running hondata i wouldn't worry about going 2 steps colder...it might make it too hard to start.
Old May 13, 2003 | 08:56 PM
Loved
Default Re: What type(temp) of spark plugs to use on JRSC'd engine? (jabroni95gsr)
So basically I can stick to my stock NGK's non plat's which I am running right now. I have my Wahlbro 255 pump installed, but I decided against installing my RC 370's until the Hondata goes in becuase i thought since I am running stock boost I should be ok with the stock injectors.
Does anyone know where I can buy the 8psi pulley from? I have a brand new CRV crank pulley, but I don't know if i want to install that instead of the 8PSI one...
Ef Si
Aug 15, 2007 12:52 PM
boostedteg15
Jul 4, 2006 09:59 PM
96turbob18c
Jun 20, 2004 08:52 PM
Racerage1
Apr 3, 2003 09:28 AM
PTownGSR
Jun 5, 2002 05:14 AM
