b16a guys-what are you launching at with this set up...
Old May 13, 2003 | 05:30 PM
mycvc8u2's Avatar
Default b16a guys-what are you launching at with this set up...
i have only been in the honda game for l**** 18months and am building my 3rd ride.
1989 crx dx
b16a-12:1 cr
ctr cams and valvetrain-estimated 200whp
running lenso 13*8 with slicks
i am curious at what rpm to launch and do you guys just drop the clutch or feather it? the car will be done in like 2-3 weeks.
i had a 1991 se-r turbo for 2 years that i had built the ran 11.8's but tat car had very nice torque. i used to just feather the se-r off th line at like 3500rpm.
the hb in my sig ran 13.8-14.1 on gsr stocks with bfg's. if i tried to drop it @ like 5k and the car would buonce pretty bad-it didnt seem to be moving so i tried feathering it off the line and this worked well at like 3k but i had really high 60 foot-like 2.4
so any help will be appreciated-check out my old hb in the sig..
Old May 14, 2003 | 06:50 AM
Timmay's Avatar
Default Re: b16a guys-what are you launching at with this set up... (mycvc8u2)
heat the slicks up and launch high 7000 or so
Old May 14, 2003 | 08:37 PM
allmtr's Avatar
around 6 or 7 sounds about right. what is the slick size. my friend uses 20 inches and they work fine. he launches at 5 on 20 inch slicks. i personally think theyre too small. but what do i know
Old May 16, 2003 | 09:36 AM
k20pinay's Avatar
hey, why does the question have to say b16a "guys" how do you know that some girls aren't running b16's???
just messing. i'm running a similiar set up and launch at about 7500. but the car is bogging down off the line because there isn't enough torque to keeping the tires spinning. that's the one downfall to a b16. i would try launching at about 7000 and see how you do. you want a 60 foot of 1.9 or better.
good luck to you!
Old May 16, 2003 | 09:47 AM
thegrinch's Avatar
Default Re: b16a guys-what are you launching at with this set up... (b16pinay)
Correct ! Another "WOMAN" that understands the components of "HER" car.
The lack of torque is really going kill the launch is the track is prepped good.
If the valve train is done corrrectly you should beable to launch around 7500 to 8k
However, if you have a reprogrammed PR3 or PWO you may havea problem exceeding 7500RPMs. reason is that Honda installed a safety rev switch on the clutch pedal....... hope all goes well
Old May 16, 2003 | 10:27 AM
skunked's Avatar
On my buddies B16 with 190whp, he uses 20" slicks and launchs @ 7500 w/b16 J1 tranny (4.40 final). he nails 1.7 60's almost every run. Good luck.
Old May 16, 2003 | 10:28 AM
k20pinay's Avatar
Default Re: b16a guys-what are you launching at with this set up... (skunked)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunked &raquo;</TD></TR><TR><TD CLASS="quote">On my buddies B16 with 190whp, he uses 20" slicks and launchs @ 7500 w/b16 J1 tranny (4.40 final). he nails 1.7 60's almost every run. Good luck.</TD></TR></TABLE>
damn 1.7's!!! what track is he running on?
Old May 16, 2003 | 02:17 PM
skunked's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16pinay &raquo;</TD></TR><TR><TD CLASS="quote">
damn 1.7's!!! what track is he running on?</TD></TR></TABLE>
Sacramento, Sears Point, Bakersfield....
Old May 16, 2003 | 02:29 PM
87sivtec's Avatar
we get 1.7's regularily from the honda's here at Mission BC. Very well prepped track and a 24 foot above sea level gets good horsepower!
Old May 16, 2003 | 02:49 PM
Waachback's Avatar
does he just dump the clutch or feather it?
Old May 16, 2003 | 07:31 PM
GTRCRX's Avatar
I was pulling 1.7's with my B16 on 22in. tires all motor best run was a 13.2 @101
Old May 23, 2003 | 02:41 PM
Waachback's Avatar
up
Hondaruss
Nov 14, 2007 06:09 AM
IMPORTMyth01
Apr 29, 2005 04:18 PM
yellowhonda88
Nov 24, 2003 12:55 PM
Timmayeg
May 15, 2003 02:58 AM
mycvc8u2
May 13, 2003 06:02 PM
