rc injectors
i just bought some 310cc rc injectors on line and the guy says that most people use these injectors for their honda/acura, he used it in his audi a4. but when i got them the injectors dont seem to fit properly. the o-ring seems to be to big for the fuel rail. do i have to modify the injectors at all?? are the injectors for the audi a4 and gsr's compatible? any help is appreciated.
perhaps you need honda o-rings? just an idea. i was always under the impression that all RC injectors are the same but that each make/model uses different rings and spacers. i could be wrong though.
i hope all the rc injectors are the same, but the clip doesnt seeme to fit either. can i shave some of it and click it in? will the clip send different signals to the ecu?
whats up man,,, what year motor are you running?? give me some more info on your setup,, i believe all rc injectors are obd1, because like me, 98 gsr motor,, i had to splice in obd1 injector clips for them, all the clips are the same by the way, i think if you can rig them in by shaving them that you'll be ok,,, also just make sure that they are saturated injectors unless you plan on running a resistor pack for peak and holds,,,,let me know
i am also sure that you need stock honda o rings for the tops and the correct maifold spacers for the bottom,,, your manifold should have those,, just make sure when you put the stock honda o-rings on the tops, to lube them with vaseline or some type of lube so you dont blow the seals, they rip mad easy
