help removing bolt from lower strut mount
Old May 13, 2003 | 03:39 PM
smoky's Avatar
Default help removing bolt from lower strut mount
Hey guys was hoping someone has run across this before and could help me out or give some ideas to try. what i have is a lower strut mount bolt that will not come out. i have tried to beat it out using a punch and bf hammer, then i torched it up and beat on it some more with the bf hammer with no luck. both the head of the bolt and nut have broken off. thanks
Old May 13, 2003 | 03:47 PM
tonyxcom's Avatar
Default Re: help removing bolt from lower strut mount (smoky)
search, this is covered at least twice a week.
Old May 13, 2003 | 03:48 PM
92CIVICCX's Avatar
take lca off and drill it out or get it pressed out and get new bushing pressed in at a shop.. there are alot in milwaukee
Old May 13, 2003 | 03:50 PM
the-one1's Avatar
that happened to a frens accord, we cut the bolt between the lca and fork, press out the bushing or bolt and put new ones in
Old May 13, 2003 | 04:02 PM
smoky's Avatar
how hard are the bushings to push in ??
Old May 14, 2003 | 06:49 AM
JustinL's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smoky &raquo;</TD></TR><TR><TD CLASS="quote">how hard are the bushings to push in ?? </TD></TR></TABLE>and how much do they usually cost and where to buy?
Old May 14, 2003 | 08:02 AM
pdiggitydogg's Avatar
if youre changing struts, then just cut the ****** (I did )
if youre not then take off the lca and drill it out ( ...but it works)
scoob8000
Feb 9, 2014 01:46 PM
RiTtEk401
26
Oct 18, 2011 02:58 AM
chrisff521
Suspension & Brakes
10
Apr 13, 2010 07:11 AM
JDM.K20
Suspension & Brakes
13
Jun 16, 2007 06:22 PM
gpilethbridge
Apr 4, 2007 01:41 PM
