will a stock b16 header fit on a b18 motor
Old May 13, 2003 | 12:59 PM
Dodger2940's Avatar
Default will a stock b16 header fit on a b18 motor
I need it to pass smog with the referee. Will the stock header from a 2000 civic si bolt up to a 98 gsr. thanks.
Old May 13, 2003 | 01:09 PM
cleggboy's Avatar
i believe that it is the same bolt pattern but the only difference is the length of the runners. the b16's may be too short
Old May 13, 2003 | 02:16 PM
RenoRacing's Avatar
Default Re: (cleggboy)
it'll work fine, i've used b16 manifold on ls/vtec and straight ls as well.
Old May 13, 2003 | 02:18 PM
B2FiNiTY's Avatar
Default Re: will a stock b16 header fit on a b18 motor (Dodger2940)
it will bolt up to the head but not sure about the car.
Old Sep 28, 2004 | 10:05 PM
lsvtecdc4's Avatar
back from the dead because I used search.
will the header length be the same or will I have to modify the cat length.
tia
Old Sep 28, 2004 | 10:25 PM
ApexOne's Avatar
Default Re: will a stock b16 header fit on a b18 motor (lsvtecdc4)
If it is a B-series motor or head it will bolt up. The two blocks are the same size. garenteed to fit.
Old Sep 28, 2004 | 10:55 PM
jDMJeRk's Avatar
Default Re: will a stock b16 header fit on a b18 motor (ApexOne)
any bseries header will fit any any bseries head. the only problem is the length of the header and wether or not it has two o2 sensors.
hth
Old Sep 28, 2004 | 11:12 PM
W.O.P.'s Avatar
Default Re: will a stock b16 header fit on a b18 motor (jDMJeRk)
will a stock itr header bolt up to a ls? and if so will it make any gains over stock ls header?
Old Sep 29, 2004 | 07:07 AM
lsvtecdc4's Avatar
Default Re: will a stock b16 header fit on a b18 motor (1quickLS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1quickLS &raquo;</TD></TR><TR><TD CLASS="quote">will a stock itr header bolt up to a ls? and if so will it make any gains over stock ls header?</TD></TR></TABLE>
ITR header will bolt up and be the correct length as the LS header.
skiracer8148
Mar 3, 2007 01:18 PM
cthan3o3
Aug 10, 2005 09:26 AM
93H22A
Dec 10, 2004 07:01 PM
Honda4CX-T
Apr 10, 2003 07:47 AM
redworm
Apr 10, 2003 04:41 AM
