B18 non vtec swap questions...
Old May 13, 2003 | 11:45 AM
UNDER PRESSURE's Avatar
Default B18 non vtec swap questions...
My cousin just bought a b18 for 150.00 and we plan on putting it in this weekend now my question is will this engine go into his 90 crx si without a mount kit? The reason i'm asking is because I was talking to a guy at the track with the same set up and he said he used stock motor mounts only I don't know if he was talking about stock crx mounts or integra mounts. Any help is appriciated thanx.
Old May 13, 2003 | 12:54 PM
Redline130's Avatar
Default Re: B18 non vtec swap questions... (UNDER PRESSURE)
No, you will need some sort of B-series mount kit.
Old May 13, 2003 | 02:16 PM
Default Re: B18 non vtec swap questions... (Redline130)
thanx for the info bro.
Old May 13, 2003 | 02:21 PM
Hondasaurs's Avatar
You'll need a B series shift linkage, axles, and clutch cable too!
Old May 13, 2003 | 03:08 PM
ThatRicerDaniel's Avatar
if you dont know the awnser the to that question i would seriously suggest not jumping into it this weekend. wait untill you know everything you need to know other wise things will go bad fast.
Old May 13, 2003 | 03:22 PM
Hondasaurs's Avatar
Default Re: B18 non vtec swap questions... (NitrousDreamz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NitrousDreamz &raquo;</TD></TR><TR><TD CLASS="quote">if you dont know the awnser the to that question i would seriously suggest not jumping into it this weekend. wait untill you know everything you need to know other wise things will go bad fast.</TD></TR></TABLE>
Good Point! There is a lot of little things you will run into. For example: You need B series shift linkage, but it won't bolt up to an EF. It has to be cut and welded. You will also run into wiring issues reguardless if its MPFI or not.
Old May 13, 2003 | 11:55 PM
I_love_my_Crx's Avatar
since its an si u just take the wire harness off of the si and put it on the b18...
Old May 23, 2003 | 05:01 PM
Hondogg's Avatar
ok so I know you might have heard this a thousand times but I am looking at picking up a 92 GS B18A1 W/cable trans I want to swap it into my 93 CX hatch and I am just wondering what wire harness I will use? will i have to change anything? also would it be in my best intrest to just dicth the cable tranny and use a hydro one? Will I need to cut and weld my linkage? PLEASE HELP ME !!!
Sorry for the dumb Q's
P.S. I have searched and cant seem to find what im looking for...
si90rex
Jun 20, 2007 04:14 AM
CRX30436
Mar 19, 2007 07:44 AM
kcjohnnyboy
Feb 23, 2006 10:50 PM
em Dot
Dec 5, 2005 12:06 PM
turbo*s2k
Mar 1, 2004 03:22 PM
