Help!!! Oil low to none
I checked my oil last week it was a little low so i filled her up a bit. Today im doing some maintenance and there is none!!!!!! ZERO!!!! the dip stick was clean!!! There are no big puddles of oil in my garage and i didnt notice any at school or work. WTF!!! Im scared. What could have happened? What could i have damaged and how do i check?
top off your oil... after one qt, wait a few minutes and then check the dipstick again... if it's still dry, lather, rinse, and repeat.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Thrillhouse »</TD></TR><TR><TD CLASS="quote">Im doing that now but could i have done some damage?</TD></TR></TABLE>
Depends on how low it really was. Tell us how much oil you have to add to get it back to full. Did your oil pressure idiotlight ever come on?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake »</TD></TR><TR><TD CLASS="quote">
Depends on how low it really was. Tell us how much oil you have to add to get it back to full. Did your oil pressure idiotlight ever come on?</TD></TR></TABLE>
This happened to me when I was up at school over a year ago. I was driving, and the oil pressure light came on. I headed right on over to Costco and bought a case of Mobil 1 10w30 Synthetic. Got to the parking lot and started topping off. One quart in, checked dipstick, was dry. Another quart in, checked dipstick, dry. Finally, on my 3rd quart, I was halfway between the dots. What could've happened? I wasn't aware of my car burning any oil until then... that was about 70k miles or so, I think. What damage could I have done? Compression test results are bad =\ 150's in two cylinders, 180's in the other two.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by free_punk »</TD></TR><TR><TD CLASS="quote">i go through oil way fast too. I usually put between 3-5quarts of oil on top of an oil change every 3000 miles. </TD></TR></TABLE>
Wow, that IS way too fast. Something is definitely wrong.
are you running the oem valve cover freash air tube? You know the thing everyone puts a breather on? If you got the stock tube take apart your intake and check for massively abnormal amounts of oil in the intake tube. Also check you PCV valve, how is your idle?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black-LS »</TD></TR><TR><TD CLASS="quote">are you running the oem valve cover freash air tube? You know the thing everyone puts a breather on? If you got the stock tube take apart your intake and check for massively abnormal amounts of oil in the intake tube. Also check you PCV valve, how is your idle?</TD></TR></TABLE>
what is the difference between a breather filter or the tube running to the intake? thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teg-your-it »</TD></TR><TR><TD CLASS="quote">
what is the difference between a breather filter or the tube running to the intake? thanks</TD></TR></TABLE>
in California you'll fail the visual part of the emissions test. But for most cars the breather is not benificial. FI cars may need it so oil doesn't get sucked out the valve cover.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Thrillhouse »</TD></TR><TR><TD CLASS="quote">No oil in the intake. And idel is steady at 750 ish. </TD></TR></TABLE>
looks like you got a real mystery here... is it getting burned? Hows your exhaust look?
Yah checking your oil when your motor is running is not acurate at all since the oil is being pulled from the oilpan as soon as its started...when the engine is cold and all the oil has run down into the oil pan is when your saposto check it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Integraholic »</TD></TR><TR><TD CLASS="quote">Ummm, you're supposed to check the oil when the engine is warm......</TD></TR></TABLE>
Ummm, you are COMPLETELY WRONG.
all this check oil stuff
im getting confused (LOL)
cold engine level ground thats all.
no puddles thats good
so next step is burning
how bout your exhaust
while car is running rev up a couple of time
and check tail pipe and ground if you see any black markins on
ground you are burning oil
simple test.
and like the other post says add oil until you see it in the dispstick
simple test.
Draggin99Si
Jun 15, 2007 09:34 PM
