b16 sputtering problem
well in my crx i did the b16 swap and when driving it, it has a sputtering problem..no check engine light, everything works perfectly..i put a new cap+rotar on it, along with plugs and wires..when i hit about 3 k rpm's, she has a slight sputter, then comes out of it..vtec has fine engagment, but i just cant figure out what this sputtering problem is..if i have it in 1st gear, and slowly take it to around 6500rpm, it sputters real bad, but mostly just when it hits 3k..its consitantly doing it right around that powerband..
i was thinking about changin the fuel fliter, figured that couild have caused some of it..never thought about advancing timing but i will try it..thanks, anyone else with suggestions?
Switch your O2 sensors. I had the same exact problem and my sensors were backwards. I changed them and it runs perfectly now.
https://honda-tech.com/zerothread?id=460514
If you go WOT does it pull strongly or does it bog? If it's a problem with the O2 sensors being crossed putting it into WOT will bypass O2 sensor output, so the sputter will disappear. If it's a problem with fuel or spark going WOT will probably cause it to bog.
honda_del_sol
Dec 6, 2010 01:40 PM
ExedyHF02
Oct 18, 2006 08:56 AM
