Is this the trim panel I need for my pocket install?
Old May 13, 2003 | 07:03 AM
The1JoshuaB's Avatar
Default Is this the trim panel I need for my pocket install?
I installed my Kenwood cd/tuner into the pocket, and the trim panel that came with the unit doesn't fit. I'm sure it's designed to fit a regular installation...like if I had replaced the factory radio. Anyway, what is the simplest option other than cutting out the middle of the trim panel and making it shorter? Is this what I need?
And more specifically, does the middle piece look like the trim panel I'm after?
From http://www.energenix.com/ameri....html
American International HON-K808
honda civic dash kit
$14.95
Features
For 1996-98 Honda Civic
Factory Textured ABS Plastic
Fits DIN and Shaft Radios
Adapts to Factory Pocket
Recessed DIN Opening
Matches Perfectly to Dash Contour
Old May 13, 2003 | 07:33 AM
nOOber's Avatar
Default Re: Is this the trim panel I need for my pocket install? (The1JoshuaB)
that middle one is the money shot. assuming you have a 96-98 civic...
That's the one where the one side has the dash curve 'built in'
Old May 13, 2003 | 08:33 AM
Default Re: Is this the trim panel I need for my pocket install? (nOOber)
Thank you. Yes. I will order it.
Old May 21, 2003 | 03:37 PM
Well, the American International part # HON-K808 is trim for the factory radio, not for the pocket. Too bad for me. Here is a picture.
Novz
Audio / Security / Video
Feb 3, 2011 07:18 AM
cybergreencivic
Nov 16, 2008 09:56 AM
tyronne1126
Nov 6, 2008 07:15 PM
E.Honda
Aug 30, 2006 06:43 PM
SiRk
Jan 7, 2006 10:21 PM
