help! VIS hood not fitting!
Old May 12, 2003 | 11:26 PM
i HAVEtheADVANtage
Guest
Posts: n/a
Default help! VIS hood not fitting!
i just got a used VIS cf hood with pins. nice condition, but the hood wont close all the way! it will latch, and then it wont close. so it looks like its popped all the time. i dont know why. im starting to think maybe thats why it has the pins.
anyone help? please!
Old May 12, 2003 | 11:30 PM
GSRrR's Avatar
Default Re: help! VIS hood not fitting! (i HAVEtheADVANtage)
try pushing down harder right at the hinge.
B2FiNiTY's Avatar
Adjust your hood latch.
Old May 12, 2003 | 11:35 PM
iam7head's Avatar
Default Re: help! VIS hood not fitting! (B2FiNiTY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">Adjust your hood latch. </TD></TR></TABLE>
and both of the rubber pieces.
Old May 12, 2003 | 11:49 PM
i HAVEtheADVANtage
Guest
Posts: n/a
Default Re: help! VIS hood not fitting! (iam7head)
thanks! i thought my intake was in the way, and it still didnt fit. so i got mad and pushed really hard.
it closed.
thanks guys! ill post pics when i get the hood cleaned
Old May 12, 2003 | 11:50 PM
i HAVEtheADVANtage
Guest
Posts: n/a
and how do i adjust the hood latch, i need to make it higher so its not so hard to close
Old May 12, 2003 | 11:53 PM
B2FiNiTY's Avatar
There should be 3 10mm bolts. Mark where the latch is right now and after loosening them, adjust according. Use the marking as a reference point.
Old May 12, 2003 | 11:54 PM
i HAVEtheADVANtage
Guest
Posts: n/a
the hood is kinda dull in the middle. where can i take it to make it look brand new. i put meguiars scratch X on it, and then some gold class. but its still dull.
maybe a good buffing? or do i need it clear coated?
Modified by i HAVEtheADVANtage at 9:05 AM 5/13/2003
Old May 13, 2003 | 12:13 AM
B2FiNiTY's Avatar
Probably needs to be buffed.
Try toothpaste for scratches on the hood. Works great.
Old May 13, 2003 | 12:16 AM
i HAVEtheADVANtage
Guest
Posts: n/a
good buffing eh. it kinda looks like i left wax on the hood or something. just really dull. i searched for this, and people said that i have to get it clear coated. ??
its not dull all over, just in the middle
Old May 13, 2003 | 12:35 AM
B2FiNiTY's Avatar
Try buffing it but if it does not work then clear coat must be done. I might cost a lot and might not be worth it in the end.
I would look at it this way:
1) paint it
2) sell it and get a new one.
3) make the current one look nice
Old May 13, 2003 | 02:33 AM
i HAVEtheADVANtage
Guest
Posts: n/a
i dont know how much i can get for it.
it has thin cracks around the hoodpins, maybe 1 or 2
Old May 13, 2003 | 02:49 AM
B Speed's Avatar
put super glue in the cracks.
Old May 13, 2003 | 03:11 AM
i HAVEtheADVANtage
Guest
Posts: n/a
Default Re: help! VIS hood not fitting! (B Speed)
you can see the cracks, you cant feel them. its a VIS hood. very sturdy.
and it came with Nokya hood pins that are supposed to mount into the holes on the radiator support. but it didnt come with the other stuff. it just came with the pins on the hood. anyone know where i can get the other part that i need for the hood pin to work. or do i need to buy a whole new assembly?
Old May 13, 2003 | 03:21 AM
coupey's Avatar
to get the dull spots out yer going to have to ge it re-clear coated...buffing isnt going to do you any good
Old May 13, 2003 | 05:01 AM
i HAVEtheADVANtage
Guest
Posts: n/a
Default Re: (nine nine si)
how much is new clear coat?
Old May 13, 2003 | 07:04 PM
EF9RacerWhoa!'s Avatar
Default Re: (i HAVEtheADVANtage)
Devo94ac
Mar 9, 2006 05:47 AM
initialvtec
Nov 9, 2004 02:33 PM
Arsenal
Feb 17, 2004 03:18 PM
CivicHb04
Jan 8, 2003 03:53 PM
