Does 240 ft lbs at the wheels sound excessive for NA and all stock internals.
Old May 12, 2003 | 09:18 PM
B18C7's Avatar
Default Does 240 ft lbs at the wheels sound excessive for NA and all stock internals.
Im looking at a dyno chart here of a B18c7 type R engine Aussie spec
and its claiming peak power of 119kw at the wheels and 330nm of torque o r
161hp at 8381 Rpm
243 ft/lbs at 6314 rpm
That equates to 243 ft lbs at the wheels.
This car consistently pulls 13.5 seconds 1/4s with 0-60mph times of 5.5s and 5.6s
It has IHE, the usual plus some crazy asian man at the dyno doing the vafc tuning. It is running sweet 4-2-1s with tapered 2.5 inch collector and this amazing DIY fan driven cold air induction system that is like 7 inches in diameter but is this a normal Torque figure for an 01 Type R
Can 3 degrees more advance on an intake cam do that much?
CAn someone tell me If they have smilar numbers in a B18c7 R engine
Thankyou
Old May 12, 2003 | 09:20 PM
uNF$@#!'s Avatar
Default Re: Does 240 ft lbs at the wheels sound excessive for NA and all stock internals. (B18C7)
does that sound even remotely NA?
1.8l is big and all, but i dont recall it being a 5.0L rustang.
Hybrid ctr's Avatar
Old May 12, 2003 | 09:37 PM
743power's Avatar
Default Re: Does 240 ft lbs at the wheels sound excessive for NA and all stock internals. (Hybrid ctr)
sure you dont have the hp and torqu mixed up, those numbers are impossible.
Old May 12, 2003 | 09:43 PM
rodimus's Avatar
some crazy asian man at the dyno?
good for atleast 30 lbs of torque!
Old May 12, 2003 | 09:46 PM
GettaluvR's Avatar
New User
Default Re: Does 240 ft lbs at the wheels sound excessive for NA and all stock internals. (EVOL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EVOL &raquo;</TD></TR><TR><TD CLASS="quote">some crazy asian man at the dyno?
good for atleast 30 lbs of torque!</TD></TR></TABLE>
i think i'll just go crazy so i can tune my car with lots torque too
Old May 12, 2003 | 09:54 PM
Dr Pooface's Avatar
Default Re: Does 240 ft lbs at the wheels sound excessive for NA and all stock internals. (GettaluvR)
Obviously he has mixed up his tq and hp.
Here is an importbuilders graph of a c5:
160 torque is possible, it seems.
Old May 12, 2003 | 10:02 PM
sgT's Avatar
sgT
Default Re: Does 240 ft lbs at the wheels sound excessive for NA and all stock internals. (Dr Pooface)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dr Pooface &raquo;</TD></TR><TR><TD CLASS="quote">Obviously he has mixed up his tq and hp.
160 torque is possible, it seems.</TD></TR></TABLE>
2 liter b18c maybe.
no,that kindof power is not possible. If someone has done it, i will go back to
my basket weaving degree.
Old May 12, 2003 | 10:03 PM
01CWITR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dr Pooface &raquo;</TD></TR><TR><TD CLASS="quote">Obviously he has mixed up his tq and hp</TD></TR></TABLE>
i think so too
Old May 12, 2003 | 10:15 PM
baonest1's Avatar
Default Re: Does 240 ft lbs at the wheels sound excessive for NA and all stock internals. (sgT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sgT &raquo;</TD></TR><TR><TD CLASS="quote">
2 liter b18c maybe.
my basket weaving degree.</TD></TR></TABLE> which univ.??? i got a masters in basket weaving..
Old May 12, 2003 | 10:35 PM
dax-es's Avatar
You mean like my 77 Civic has 50hp and nearly 300 lb by that logic. I have a feeling that you're using a Dyno Dynamics dyno.
Old May 13, 2003 | 04:27 AM
swlabhot's Avatar
Does he think hes GOD??
Old May 13, 2003 | 04:43 AM
REDNECK TYPE-R's Avatar
Default Re: Does 240 ft lbs at the wheels sound excessive for NA and all stock internals. (swlabhot)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by swlabhot &raquo;</TD></TR><TR><TD CLASS="quote">Does he think hes GOD?? </TD></TR></TABLE>
WHY IS HE SELLING TEST PIPES TOO?
Old May 13, 2003 | 04:52 AM
Tommy_Gunns's Avatar
Default Re: Does 240 ft lbs at the wheels sound excessive for NA and all stock internals. (baonest)
You too. I'm going to the international convention next month
LOL
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by baonest &raquo;</TD></TR><TR><TD CLASS="quote"> which univ.??? i got a masters in basket weaving..</TD></TR></TABLE>
Old May 13, 2003 | 05:32 AM
aklucsarits's Avatar
New User
The torque sounds just about double what it should be. This happens on a DynoJet when the dyno operator mis-configures the cylinder firing setting. It's probably really 161hp and 121.5 lb.ft. (243/2 = 121.5lb.ft)
Andrew
Old May 13, 2003 | 05:37 AM
YelLowITR's Avatar
Default Re: Does 240 ft lbs at the wheels sound excessive for NA and all stock internals. (aklucsarits)
ok.. this is funny.. i never seen any R motor put down that much more torque than hp
Old May 13, 2003 | 05:51 AM
sackdz's Avatar
Default Re: Does 240 ft lbs at the wheels sound excessive for NA and all stock internals. (YelLowITR)
I was a big underwater basket weaver in my day.
Old May 13, 2003 | 05:54 AM
fredtoast's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by baonest &raquo;</TD></TR><TR><TD CLASS="quote"> which univ.??? </TD></TR></TABLE>
Rice University in Houston?
Old May 13, 2003 | 07:43 AM
sneakychaos's Avatar
Default Re: Does 240 ft lbs at the wheels sound excessive for NA and all stock internals. (REDNECK TYPE-R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by REDNECK TYPE-R &raquo;</TD></TR><TR><TD CLASS="quote">
WHY IS HE SELLING TEST PIPES TOO?</TD></TR></TABLE>
bwhahahaahhahaha
Old May 13, 2003 | 07:46 AM
FAST4DR's Avatar
OWNED!!!!
Old May 13, 2003 | 08:20 AM
Austin's Avatar
Default Re: Does 240 ft lbs at the wheels sound excessive for NA and all stock internals. (DA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA &raquo;</TD></TR><TR><TD CLASS="quote">
You mean like my 77 Civic has 50hp and nearly 300 lb by that logic. I have a feeling that you're using a Dyno Dynamics dyno. </TD></TR></TABLE>
That sounds like the DynoDynamics dyno is reading the Effective Torque, and not calculating for the gearing that is present, essentially giving you what is really at the wheels. The DynoJet computes it all out for us and gives us readings based off of gearing and Effective Torque, but when I used the DynoDynamics on the print out of the figures it gives you Effective Torque.
Austin
Old May 13, 2003 | 08:01 PM
dax-es's Avatar
Default Re: Does 240 ft lbs at the wheels sound excessive for NA and all stock internals. (Austin)
That's what I figured from the runs done on the Civic and Integra. 300 / 4.933 (stock final drive) is roughly 60lb-ft / 80Nm, which sounds about right for this car. I've also noticed DynoDynamics tend to read somewhat low.
Stock B18C 125kW flywheel, 90kW wheels.
Stock EB2 48kW flywheel, 38kW wheels.
I don't think there are any DynoJet dynos local to us here in Melbourne, AU.
Old May 13, 2003 | 08:21 PM
nfn15037's Avatar
Yeah, i bet him and Larry @ Endyn built this motor
Old May 14, 2003 | 05:46 AM
CHEETAH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C7 &raquo;</TD></TR><TR><TD CLASS="quote"> peak power of 119kw at the wheels and 330nm of torque o r
161hp at 8381 Rpm
you prolly just switched your readings around ... those numbers and RPMs are similar to my 2 liter Del Sol's if you switch them:
Greg
Old May 14, 2003 | 07:22 AM
QCKGSR's Avatar
That sounds a little to much for NA and stock internals
