spoon rear lower tie bar question
Old May 12, 2003 | 08:55 PM
Judah's Avatar
Default spoon rear lower tie bar question
Does anyone have the spoon rear lower tie bar?
I got mine today but it looks like it's going to hit the brake lines. Anyone have one installed, or know if it'll fit?
TIA
Old May 12, 2003 | 09:25 PM
JDC2's Avatar
Default Re: spoon rear lower tie bar question (TypeR895)
you have to cut away some of the bracket to make it fit correctly. if you look at where the tie bar bracket sits over the abs bracket you should cut around that. becareful not to cut the abs lines! hope this helps
Old May 13, 2003 | 12:55 PM
Judah's Avatar
Default Re: spoon rear lower tie bar question (JDC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDC2 &raquo;</TD></TR><TR><TD CLASS="quote">you have to cut away some of the bracket to make it fit correctly. if you look at where the tie bar bracket sits over the abs bracket you should cut around that. becareful not to cut the abs lines! hope this helps</TD></TR></TABLE>
Damn, maybe I'll just throw it on the EG instead...
Thanks!
iheartjayDem
Jul 12, 2006 12:18 PM
OMG THE GOGGLES
Jun 3, 2006 10:04 PM
RIX982DRLS
Jun 10, 2004 08:43 PM
yellow blur
Oct 13, 2003 11:44 PM
mickey513
Mar 31, 2003 02:23 PM
