cleaning apexi filter?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mario »</TD></TR><TR><TD CLASS="quote">nope.
"You can try, but will not succeed." Russ from Friends.</TD></TR></TABLE>.
what an informative reply
I believe you can use the K&N recharging kit http://www.performance-air-fil....html like so. Well thats what my friend uses on his AEM filter. I think the apexi is the same material as AEM
And I quote
"...The Power Intake is a maintenance-free dry-type air filter and will alleviate the problem of filter oil from "wet" air cleaners interfering with the air-flow meter. Accept no imitations."
courtesy of Apex'i USA.
I've put in bold the information that pertains to this particular topic. If you cant figure it out, then you are in dire need of serious common sense help.
FIN
FIN
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kendogg »</TD></TR><TR><TD CLASS="quote">.
I believe you can use the K&N recharging kit...I think the apexi is the same material as AEM</TD></TR></TABLE>
Your answers are neither definitive or accurate.
You CANNOT use K&N's recharging kit!
The Apex'i filter is NOT the same as the AEM filter!
AEM used K&N as their filter supplier for a couple of years before they made their own filter element. Essentialy a K&N knockoff.
That's two strikes for you, care to go for a third?
I personally dont think any filter can last forever..new filter every year for me.
i just dusted out my old filter and blow it with a high pressure air hose.
then i got the 200 HKS foam filter, I wash those
the filter replacement is like 20 buck+tax
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jeff K. »</TD></TR><TR><TD CLASS="quote">so if i dont need to clean it, do i need to buy a need one or use the same one forever?</TD></TR></TABLE>
man o man.... use it forever....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iam7head »</TD></TR><TR><TD CLASS="quote">I personally dont think any filter can last forever..new filter every year for me.
the filter replacement is like 20 buck+tax</TD></TR></TABLE>
Might want to think about that HKS filter.... read this http://mkiv.com/techarticles/filters_test/2
