Where does your needle stay on the temp guage?
I want to get an idea of what the average integra runs as far as temp once the car is warmed up and running.
Please state wat motor u got and where exactly it falls... like for me...
94 LS - little higher than 1/3 from left so it falls right where the edge of that one picture is on the temp guage.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shockerstickers »</TD></TR><TR><TD CLASS="quote">3/8ths</TD></TR></TABLE>
Nice peter north avatar btw
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jeff K. »</TD></TR><TR><TD CLASS="quote">I have a 95 ls and my needle is a about half way point from the right side and the middle</TD></TR></TABLE>
whoa~ are you serious? dats hella high no?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93hb »</TD></TR><TR><TD CLASS="quote">i have a 98 ls motor in my eg hatch and the temp needle doesn't even go up to the normal mark. it stays a little below that.</TD></TR></TABLE>
where is the normal mark? halfway on the guage?
Not to hijack the thread but is there a way to reset the temp gauge? I accidentally bumped the needle when I had them stupid indiglo gauge installed
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SilverB18C1 »</TD></TR><TR><TD CLASS="quote">like this \ </TD></TR></TABLE>
bleh I tried that but it doesn't seem accurate. When it over heated the needle was little over the middle part.
i think people should also state if they're running on what kind of radiator fluid (ie radiator fluid, water, 1/2 and 1/2, or redline fluid) I find my car runs cooler on redline and wather
o yeah, its about less then 1/4.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDC2 »</TD></TR><TR><TD CLASS="quote">i think people should also state if they're running on what kind of radiator fluid (ie radiator fluid, water, 1/2 and 1/2, or redline fluid) I find my car runs cooler on redline and wather
o yeah, its about less then 1/4.</TD></TR></TABLE>
whoa
o yeah, its about less then 1/4.</TD></TR></TABLE>whoa
The temp gauge should be slightly less than half. Running a higher mix of coolant to water to reduce the engine temperature to less is not recommended. Your engine is "happy" at it's normal operating temperature. Running an engine too cold is not good for it and there's no advantage in doing so. Every hear of letting your engine warm up to normal operating temperature before going wild with it? Some cars will even lower the redline until the engine gets to normal operating temperature. A 50/50 mix is what should go in the radiator. If your car runs hotter, then there is a problem with the cooling system (radiator, thermostat, sensors, etc.) and should be diagnosed by a competent mechanic.
o yeah, its about less then 1/4.</TD></TR></TABLE>The temp gauge should be slightly less than half. Running a higher mix of coolant to water to reduce the engine temperature to less is not recommended. Your engine is "happy" at it's normal operating temperature. Running an engine too cold is not good for it and there's no advantage in doing so. Every hear of letting your engine warm up to normal operating temperature before going wild with it? Some cars will even lower the redline until the engine gets to normal operating temperature. A 50/50 mix is what should go in the radiator. If your car runs hotter, then there is a problem with the cooling system (radiator, thermostat, sensors, etc.) and should be diagnosed by a competent mechanic.
for some reason.....it used to be in the middle..........then i started puting mods on my car, used octane boost a couple of times, and now its inbetween the C and the half way mark
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by laseca »</TD></TR><TR><TD CLASS="quote">
The temp gauge should be slightly less than half. Running a higher mix of coolant to water to reduce the engine temperature to less is not recommended. Your engine is "happy" at it's normal operating temperature. Running an engine too cold is not good for it and there's no advantage in doing so. Every hear of letting your engine warm up to normal operating temperature before going wild with it? Some cars will even lower the redline until the engine gets to normal operating temperature. A 50/50 mix is what should go in the radiator. If your car runs hotter, then there is a problem with the cooling system (radiator, thermostat, sensors, etc.) and should be diagnosed by a competent mechanic.</TD></TR></TABLE>
Thank you for confirming my belief.
