machine shop costs? b16a guys
Old May 12, 2003 | 06:45 PM
mycvc8u2's Avatar
Default machine shop costs? b16a guys
how much should i expect to pay a machine shop to install my overbore pistons and new rods on my block?? or just to machine the block to accept the pistons and clean **** up?? anyone know any good shops in the ohio valley or pittsburgh pa area?? thanks
Old May 12, 2003 | 08:27 PM
crexer's Avatar
Default Re: machine shop costs? b16a guys (mycvc8u2)
I know to have your block honed it usually runs 10-15 dollars per cylinder; to clean the block shouldnt cost more than 20-25 and to actually bore it out I would say 20-30 a cylinder.
Old May 13, 2003 | 01:27 AM
ExospeedAMcrx's Avatar
Default Re: machine shop costs? b16a guys (crexer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crexer &raquo;</TD></TR><TR><TD CLASS="quote">I know to have your block honed it usually runs 10-15 dollars per cylinder; to clean the block shouldnt cost more than 20-25 and to actually bore it out I would say 20-30 a cylinder.</TD></TR></TABLE>
Its goign to cost a bit more than $200 to get this all done. Machining itself will cost $300 or so, plus installation of the piston to the rods and then the assembly of the block. which will run from $200-600 depending where u go and how good they really are.
I would suggest getting new bearings at the same time. you are already there.. why not just redo it all during the assembly. OEM honda bearings up to $220 for complete bearing set.
Old May 13, 2003 | 05:19 AM
mycvc8u2's Avatar
Default Re: machine shop costs? b16a guys (exospeedAMcrx)
thanks. oh, i am rebuilding myself with all new bearings. i was just curious for the machine work only. thanks
mtownek9
Oct 5, 2007 09:02 PM
angry_LS
Jan 27, 2005 08:32 AM
FAUCON
Jul 1, 2004 07:50 PM
GapxGuy
Dec 26, 2002 05:32 AM
Turbo_Teg
Dec 24, 2002 05:56 PM
