someone wanna doublecheck my rebuild?Am i missing anything?
**completed tasks**
Golden Eagle block bore&hone+oring
Crower rods
Je Pistons
Stock head tanked&reasembled, valve adj., resurfaced
crank&flywheel balanced and micropolished
**parts being orderd tomorrow**
Oil pump
Oil pump gasket
Oil pan gasket
Head gasket
Valve cover gasket
main bearings
rod bearings
thrust washers
**parts im looking for**
Crank pulley
Timing belt
head studs
cam seals(ALL)
Vtec/turbo conv.
Crower rods
Je Pistons
Oil pump
Oil pump gasket
Oil pan gasket
Head gasket
Valve cover gasket
main bearings
rod bearings
thrust washers
Crank pulley
Timing belt
head studs
cam seals(ALL)
Vtec/turbo conv.
if i have 87mm JEs' can i get 87.5mm rings on them ...i cant find 87mm rings anywhere
Stacygifford
Jan 28, 2014 06:14 PM
blackboostcoupe
Jul 26, 2006 05:12 PM
