need help. car is throwin code 71. silinder 1 misfire.
Old May 12, 2003 | 05:27 PM
Ghost Rider's Avatar
Default need help. car is throwin code 71. silinder 1 misfire.
thats right. What the topic says. i have ctr intake cam with p-28,skunk2 intake manifold,dc 4-2-1 header cold air intake, aem fpr,aem fuel rail, greedy evo. The car also makes a poping noise when I let off the gas. I wanna know if I have a burnt valve or something. Please pm me back.
Old May 12, 2003 | 05:40 PM
ragejed's Avatar
Default Re: need help. car is throwin code 71. silinder 1 misfire. (Ghost Rider)
Dunno..think the problem is your car has silinders...My car doesnt have those, I think youve been scammed.
EDIT: lol..check ur ignition crap. spark plugs and wires first. You gots a back fire.
Old May 12, 2003 | 05:41 PM
B-Tuning.com's Avatar
first of all - it's Cylinder, not silinder. (Just messin' with you, don't get bent up...)
The elusive 71-74 codes can be any number of things. Bad gas, bad ignitor in your distributor, not enough fuel pressure, too much fuel pressure, cracked injector or work o-rings on your injectors, etc, etc, etc.
Start troubleshooting - get a Helms.
Old May 12, 2003 | 06:00 PM
Burglar's Avatar
Default Re: need help. car is throwin code 71. silinder 1 misfire. (B-Tuning.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B-Tuning.com &raquo;</TD></TR><TR><TD CLASS="quote">first of all - it's Cylinder, not silinder. (Just messin' with you, don't get bent up...)
Start troubleshooting - get a Helms.</TD></TR></TABLE>
hehe, mine was 2 bad valve seals......compression test looked like this: 200-200-60-200
do a compression test BEFORE you waste money on things like ignition, fuel, etc.
get a voltmeter too and test the plugs on your injectors.
Old May 12, 2003 | 08:05 PM
Default Re: need help. car is throwin code 71. silinder 1 misfire. (Burglar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Burglar &raquo;</TD></TR><TR><TD CLASS="quote">
get a voltmeter too and test the plugs on your injectors.</TD></TR></TABLE>
Good call. Sorry to hear about the valve seals! That sucks corn.
Old May 13, 2003 | 07:18 PM
bump
bigislandc2
Aug 11, 2006 08:44 AM
v-tec maz
Apr 17, 2006 05:02 AM
FUP23
Aug 7, 2002 12:57 PM
