Direct bolt on for the Apex N1 to the JDM Header??
Old May 12, 2003 | 03:29 PM
hYpE-R-29's Avatar
Default Direct bolt on for the Apex N1 to the JDM Header??
my exhaust came in today and my Im doing the install tomorrow my question is will I need to modify the N1 to make it fit because I know the JDM header is longer than the stock header. Also I do have a carsound Cat installed also will that make a difference??
Old May 12, 2003 | 05:48 PM
hYpE-R-29's Avatar
Default Re: Direct bolt on for the Apex N1 to the JDM Header?? (hYpE-R-29)
any1???? c'mon Im trying to get ready for the norcal meet
Old May 12, 2003 | 05:51 PM
APEX i GSR's Avatar
you will need a different cat
Old May 12, 2003 | 05:54 PM
Eric R's Avatar
If you have the right Carsound Cat, you should not have any problem. You might find just a little rubbing problem with the muffler canister and the rear bumper.
Note: Rear section of N1 is a pain in the butt to put on.
Old May 12, 2003 | 10:21 PM
hYpE-R-29's Avatar
Default Re: Direct bolt on for the Apex N1 to the JDM Header?? (Tweety R)
got my carsound cat from IPSracing so Im pretty sure its the right one..thnx
SD_EM1
Oct 21, 2003 11:39 AM
Aaron M
Feb 12, 2003 04:47 AM
Smitdog
Aug 22, 2002 10:27 AM
AllMotorITR
Jul 1, 2002 03:58 AM
