Intake Manifold; Cant get t seal!
Old May 12, 2003 | 02:16 PM
forcedaccord95's Avatar
Default Intake Manifold; Cant get t seal!
hey guys,
i did a complete rebuild on my f22-b1. i started the motor a week ago and i discovered my jumpy idle is to be caused by a intake manifold gasket leak! I pulled the intake back and put gold perma seal on the gasket, tightened back down and let it set for 12 hrs. i tightened the nuts in the sequence that the dealers manual said to tighened and when i removed it i did the same. today i started it up and the same leak is still there. i went to honda today and ordered the honda oem gasket and also some honda bond, which is a sealant the dealer uses, i will be trying this tom. my question is, does anyone have any tips or has anyone had these problems?
thanks,
shane
Old May 12, 2003 | 02:59 PM
niedejb's Avatar
Default Re: Intake Manifold; Cant get t seal! (forcedaccord95)
You almost have to replace that gasket everytime since it falls apart when the IM comes off.
Just need the gasket.....NO honda bond.
Old May 12, 2003 | 04:50 PM
Chiovnidca's Avatar
And make sure to clean off all the old gasket.
Old May 12, 2003 | 08:33 PM
Stripped Honda's Avatar
99-0104
Default Re: Intake Manifold; Cant get t seal! (Chiovnidca)
dealer doesent use honda bond on a intake manifold gasket ... if you continue to have problems after this you better look at the intake manifold to see if it is warped ... put a straight edge on it
ed23cate
Jan 23, 2016 08:29 AM
GsrVtec
Sep 13, 2006 09:53 AM
Shizznaz
Sep 2, 2005 08:07 AM
jbs
Apr 5, 2004 12:07 PM
