T3/T04Es efficiency
Old May 12, 2003 | 01:52 PM
swlabhot's Avatar
Default T3/T04Es efficiency
60 trim 63a/r, at what psi is it most efficient for this trubo?
Old May 12, 2003 | 03:15 PM
shermanyang's Avatar
Default Re: T3/T04Es efficiency (swlabhot)
bump for you...I'd like to know as well. I've got a 57 trim with .63/.60 with wet floating ball bearings.
Old May 12, 2003 | 03:41 PM
intekragsr's Avatar
Default Re: T3/T04Es efficiency (shermanyang)
Boosted Hybrid told me
"The 57 trim is a great compressor since it is efficient at 8psi, as well as 20psi. The greatest efficiency range (most power to be made) is going to be in the 12-16psi range for the 57 trim. "
Old May 13, 2003 | 04:19 AM
swlabhot's Avatar
Default Re: T3/T04Es efficiency (intekragsr)
What about 60 trim 63a/r?
Anyone know? Boosted Hybrid??
Old May 13, 2003 | 04:24 AM
T-Blaze's Avatar
Ha Ha - Ur post got jacked...
Old May 13, 2003 | 04:35 AM
PM-Performance's Avatar
Default Re: (T-Blaze)
I wanna know too , ill opm this link to him this is the same turo i am runnig and Boostedhybrid is running now too insted of the 60-1
Old May 13, 2003 | 04:50 AM
BoostedB20A's Avatar
Default Re: (itr206)
what about 60 trim .82ar? what psi would that be best at? Thanks.
Old May 13, 2003 | 05:47 AM
TurbodCX's Avatar
Default Re: (BoostedB20A)
I would like to know also since i have the same turbo.
Brian
Old May 13, 2003 | 05:53 AM
Boost2NA's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T-Blaze &raquo;</TD></TR><TR><TD CLASS="quote">Ha Ha - Ur post got jacked...</TD></TR></TABLE>
LOL, ill give u a bump .
Old May 13, 2003 | 05:57 AM
TurbodCX's Avatar
Default Re: (Boosted99Si)
And i will give you a bump^^
Brian
Old May 13, 2003 | 06:03 AM
T-Blaze's Avatar
How about the 57 trim 48 ar???
Seriously, there's gotta be a table of stats sumwhere about this info???
Old May 13, 2003 | 06:13 AM
prob garret, but i dunno how to read those damn things
Old May 13, 2003 | 06:16 AM
swlabhot's Avatar
Oi you!! Stop jacking my post! Before I blaze u wit my flames!!
Old May 13, 2003 | 06:24 AM
T-Blaze's Avatar
Dawg - The only flames u blaze me wiv are the ones from ur own rear muffler.... That **** is like over 1000whp at 2psi.!!
Old May 13, 2003 | 06:39 AM
TurbodCX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T-Blaze &raquo;</TD></TR><TR><TD CLASS="quote">Dawg - The only flames u blaze me wiv are the ones from ur own rear muffler.... That **** is like over 1000whp at 2psi.!!</TD></TR></TABLE>
Hahahahahahah
lol
Brian
Old May 13, 2003 | 06:55 AM
T-Blaze's Avatar
Default Re: (TurbodCX)
It's nice to see you guys understand our 'poor' UK sense of humour...
Old May 13, 2003 | 07:49 AM
TurbodCX's Avatar
Back up!
Brian
Old May 13, 2003 | 08:14 AM
boosted hybrid's Avatar
To answer everyone's questions about the efficiencies of the compressor maps, here is the two graphs of the 57 trim and 60 trim:
57 Trim:
60 Trim:
Assuming the following:
Boost: 6psi, Intercooler Pressure Drop: 1psi, Engine RPM: 8200, Post Intercooler Temp: 130 degrees, Displacement 110 CI (1.8L), Volumetric Efficiency: 90% and Underhood temps: 85 degrees
You get Pressure Ratio: 1.476 and Airflow: 21.05
The Pressure Ratio is the Y-axis, The Airflow is the X-axis. Plot these two points on both graphs.
Boost: 22psi, Intercooler Pressure Drop: 1psi, Engine RPM: 8200, Post Intercooler Temp: 130 degrees, Displacement 110 CI (1.8L), Volumetric Efficiency: 90% and Underhood temps: 85 degrees
You get Pressure Ratio: 2.56and Airflow: 37.32
Plot the Pressure Ratio and Airflow on both graphs.
You'll see that the 57 trim is a bit more efficient than the 60 trim at lower psi, while the 60 trim owns the 57 trim on high boost. The pressure Ratio's and Airflow numbers I gave you are estimates, so if the ambient temperature changes or atmospheric pressure changes (altitude) you would have to take that into account in the calculations.
I prefer the 60 trim maps anyday over the 60-1. Using the same numbers plot them on the 60-1 Graph:
You can see that the compressor really doesnt get efficient till 14-15psi.
Old May 13, 2003 | 08:22 AM
azboy's Avatar
Default Re: (boosted hybrid)
i can't make out what those numbers are for the 57 trim map. anyone???
Old May 13, 2003 | 08:31 AM
Default Re: (azboy)
Thanks for chiming in Jeff, your knowledge is always appreciated.
Old May 13, 2003 | 08:37 AM
TurbodCX's Avatar
So if i read the .60 trim right, it is saying that the optimum is about 20-25 psi then right??
Brian
Old May 13, 2003 | 08:53 AM
Midwestrider's Avatar
Good info Jeff
Old May 13, 2003 | 08:55 AM
*Boostwerks*'s Avatar
And heres the 50 trim for more comparison...
From what I can tell, The 50 trim seems more desireable over the 57 trim, even at high boost.
Old May 13, 2003 | 09:18 AM
Default Re: (Bryson)
You are correct that the 50 trim has a better compressor map, but it does not flow nearly as much cfm as the 57 and 60 trim. The 57 trim flows 49~50lb/min, while the 60 trim flows 52lb/min. I believe the 50 trim flows 42lb/min. Choosing a compressor map is about flow and efficiency. Its a balance choosing a compressor. In the past (before Garret's GT compressor wheels) you had to trade off efficiency for total cfm (in the case of the 50 trim), or total cfm for efficiency (in the case of the 60-1). The new GT series compressor maps are efficient at lower boost levels, as well as high boost levels and flow alot of cfm. I believe the GT compressor maps are the first of their kind to break over the 80% efficiency range. Most peak efficiencies range from 70-75%, and really good compressor maps range from 75-78%.
Old May 13, 2003 | 09:49 AM
JM Performance's Avatar
Boosted hybrid...what you said confused me a bit. you said "You are correct that the 50 trim has a better compressor map, but it does not flow nearly as much cfm as the 57 and 60 trim."
but when you did the calculations you calculated Airflow: 21.05 and Airflow: 37.32. so whats the difference what its capable of if you engine can only swallow 21 lbs/min?
