ohm range on fuel level sender?
Does anyone know what the OHM range is for the fuel level sender on an 88-91 crx? I know I should just test it when the tank is either full or empty, but I figured I'd post it first and see if I get any results.
From: I told you to wait in the truck in Texas, United States
see http://www.binghamtonlife.com/...5.jpg
and also http://www.binghamtonlife.com/...6.jpg
Under the storage compartment,check for voltage on the harness
yellow/white is positive;and the black wire is negative.
With the key on,battery voltage should exist,if not check fuse#1 in the
dash fuse box.
at empty,the resistance should be 105-110 ohms
at half full,the resistance should be 25.5-39.5 ohms
at full,the resistance should be 2-5 ohms
Also, it says you can check the gauge itself by jumpering the yellow/white to the black and briefly turning the key to the on position
but it warns not to let the gauge go full scale.
dash fuse box.
myDC4rox
Dec 6, 2021 09:12 AM
ESP.net
Jan 15, 2021 07:51 AM
Master23
Nov 17, 2011 04:32 PM
