Weird sound in the Front when turning.
Old May 12, 2003 | 09:59 AM
johnny5sTypeR's Avatar
Default Weird sound in the Front when turning.
Everytime I am going between 5-15 mph and turn left or right, I hear a eerrrr sound, nothing really appears to be wrong but I thought somebody might have some ideas, it only happens when I turn, not when I am going straight.
Old May 14, 2003 | 02:22 AM
str8cyko's Avatar
Default Re: Weird sound in the Front when turning. (johnny5sTypeR)
i think your axles are going bad. check the boots on your cv joints for tears and grease.
Old May 14, 2003 | 02:54 AM
ABTDer's Avatar
Default Re: Weird sound in the Front when turning. (cycocivic)
taken anything apart recently? if you did go back to what you did and try to trace it down that way. good luck
Old May 14, 2003 | 06:23 PM
Jeff R's Avatar
New User
Default Re: Weird sound in the Front when turning. (Drunk-N-Munky)
i think this is what you are talking about. happened to my car, too.
https://honda-tech.com/zerothread?id=364346
Old May 14, 2003 | 07:55 PM
RickV's Avatar
Default Re: Weird sound in the Front when turning. (rig74)
I'm currently going through this whole sorry saga on my 01 ITR.
It is currently at the dealer (Southside Honda) where they at first tried to blame my mechanic for putting the wrong oil in (he put the oil recommended by Honda in). At the moment whilst I sit here at work they are flushing out the transmission with the supposedly correct oil in the hope that it will fix it.
My mechanic said that he was pretty sure it is the LSD which is at fault - although he checked the Honda network and mine would be the first in Aus to have the issue.
All I can say is freaking dealers - always trying to rip you off or shaft you in one way or another.
Old May 14, 2003 | 09:10 PM
nightrider's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by johnny5sTypeR &raquo;</TD></TR><TR><TD CLASS="quote">Everytime I am going between 5-15 mph and turn left or right, I hear a eerrrr sound, nothing really appears to be wrong but I thought somebody might have some ideas, it only happens when I turn, not when I am going straight. </TD></TR></TABLE>
that eerrRR noise, is it like a metal on metal sound? after my car got out of the shop, it did that and it ended up being the p/s pulley and p/s pump. it was bent so whenever i turned the wheel, the pulley would rub against the nut. check and see if the rotation of the pulley seems to be fine.
Old May 15, 2003 | 12:12 AM
RickV's Avatar
Default Re: Weird sound in the Front when turning. (nightrider)
Just got a call from the dealer - they replaced the transmission oil and the noise went away - apparently it was the wrong type. Go figure?
VTECwalka
Sep 13, 2017 04:15 PM
Terry Martin
Honda CR-V & Element
Feb 27, 2017 07:28 AM
xxmastermindxx
Feb 5, 2007 09:25 AM
burnout289
Jun 16, 2005 07:07 PM
shipsaeki
May 29, 2003 07:48 AM
