Hondata w/ 3rd gen prelude?
Old May 12, 2003 | 09:47 AM
legendboy's Avatar
Default Hondata w/ 3rd gen prelude?
I searched around and I can't find any information at all. Anybody know which ecu we can run with the B20A5 so we can use hondata??
Old May 12, 2003 | 10:03 AM
Spunkster's Avatar
Default Re: Hondata w/ 3rd gen prelude? (legendboy)
If you want to use a Hondata system, you will have to convert the car to OBD1 with an OBD1 distributor, then use a pr4, p74 or p75 ecu. As long as the car is manual you can then use either an s100 or s200 system with the options you want or need.
The problem withthe engine you mentioned is that it has nowhere near the same potential as the more modern b-series engines. It has a weird bore and stroke. Displacement (cc): 1958
Power (bhp@rpm): 135@5800
Torque (ft/lbs@rpm): 111@4000
Compression Ratio: 9.0:1
Bore (mm): 81
Stroke (mm): 95
Old May 12, 2003 | 10:56 AM
legendboy's Avatar
Default Re: Hondata w/ 3rd gen prelude? (Spunkster)
Hey, thanks for the reply. Isn't there someone on here that makes the obd0-obd1 harness? time for a search
Old May 12, 2003 | 10:59 AM
wuhungsixxx's Avatar
New User
Blown90hatch makes the stuff
93delslow315
May 27, 2010 09:23 PM
Gearhead559
Engine Management and Tuning
Nov 16, 2008 07:34 AM
1epmugenlude
Jan 6, 2006 06:26 PM
hotimportcrx
Jun 23, 2005 11:06 PM
i3oricua
Jul 8, 2003 11:05 AM
