Valve Clearance and Stock Fuel Pressure for 2000-2001 ITR?
Old May 12, 2003 | 09:05 AM
Forgiven's Avatar
Default Valve Clearance and Stock Fuel Pressure for 2000-2001 ITR?
As the topic states, I need to know the stock valve clearance and the stock fuel pressure specs for a 2k - 2k1 ITR, any help will be appreciated, thanks in advance.
Old May 12, 2003 | 09:06 AM
B2FiNiTY's Avatar
Default Re: Valve Clearance and Stock Fuel Pressure for 2000-2001 ITR? (DC4TEG)
Stock fuel pressure with the hose off is: 48-52psi
Old Feb 10, 2006 | 05:49 AM
AssPenny's Avatar
Default Re: Valve Clearance and Stock Fuel Pressure for 2000-2001 ITR? (Forgiven)
Yeah old post from the dead... But I need to know stock valve to piston clearance. Also what is a safe minimum clearance?
Old Feb 10, 2006 | 08:38 AM
Sehc Tib Alli Zerif!!!!!'s Avatar
cool guy name
Default Re: Valve Clearance and Stock Fuel Pressure for 2000-2001 ITR? (AssPenny)
Factory spec for the B18C1/5 and B16A is:
Intake: 0.006"-0.007"
Exhaust: 0.007"-0.008"
Is that what your looking for?
Old Feb 10, 2006 | 08:40 AM
cool guy name
Default Re: Valve Clearance and Stock Fuel Pressure for 2000-2001 ITR? (walker111)
Claying the motor will insure that you have sufficient clearance between the head, pistons and valves (0.035"). This process is time consuming and requires a lot of patience
You sure your gonna be able to do that?
Old Feb 10, 2006 | 10:21 AM
AssPenny's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by walker111 &raquo;</TD></TR><TR><TD CLASS="quote">Factory spec for the B18C1/5 and B16A is:
Is that what your looking for?</TD></TR></TABLE>
Thats valve lash... I was looking for clearance between the piston and the valve. I got it answered
Old Feb 10, 2006 | 10:29 AM
cool guy name
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AssPenny &raquo;</TD></TR><TR><TD CLASS="quote">
Thats valve lash... I was looking for clearance between the piston and the valve. I got it answered </TD></TR></TABLE>
How bout you post it up for everyone to see and search for!! I tried searching for you and couldnt find too much. All I got was 0.035"
Old Feb 10, 2006 | 10:40 AM
AssPenny's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D &raquo;</TD></TR><TR><TD CLASS="quote">.070 is actually what i've always used as min clearance...</TD></TR></TABLE>
Not sure what the stock clearance is.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D &raquo;</TD></TR><TR><TD CLASS="quote">depending on valvetrain, and valve float, etc... some of those nascar guys run either more or less clearance.</TD></TR></TABLE>
Old Feb 10, 2006 | 10:43 AM
cool guy name
Gracias, senor
Old Feb 10, 2006 | 02:05 PM
Eva01's Avatar
I just happned to run across these figures on the Endyn site:
Minimum Piston to Valve Clearance
Intake Valves: .050”
Exhaust Valves: .060”
Minimum Valve to Valve “Clicking” Clearance: 040”
http://www.theoldone.com/artic...s.htm
Old Feb 12, 2006 | 12:06 PM
Hooch'n's Avatar
Default Re: Valve Clearance and Stock Fuel Pressure for 2000-2001 ITR? (Eva01)
interesting
twkdCD595
Jan 28, 2008 01:37 PM
mengy007
Sep 2, 2004 11:38 AM
sleepin91teg
Jun 16, 2004 05:13 PM
mrtrex
Jun 2, 2004 04:31 PM
nsx-Animal
Sep 7, 2001 12:28 PM
