Changing timing belt, what else should I do?
Old May 12, 2003 | 06:53 AM
red00gsr's Avatar
New User
Default Changing timing belt, what else should I do?
I am going to replace the timing belt, drive/acc belts, and my water pump. Are there any other components I should replace while I'm in there?
Thanks
Old May 12, 2003 | 06:56 AM
WiggiE's Avatar
New User
Default Re: Changing timing belt, what else should I do? (red00gsr)
Check the engine mount while you have it off.
Old May 12, 2003 | 07:02 AM
IN VTEC's Avatar
timing belt tensioner
Check the cam seals and front main seal on the oil pump for leaks/weeping.
Old May 12, 2003 | 07:11 AM
IntEGNYC's Avatar
Default Re: Changing timing belt, what else should I do? (IN VTEC)
Water pump, and related washers
Old May 12, 2003 | 07:34 AM
WiggiE's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC &raquo;</TD></TR><TR><TD CLASS="quote">timing belt tensioner</TD></TR></TABLE>
Does it have a tendency to wear out?
Old May 12, 2003 | 07:47 AM
IN VTEC's Avatar
Default Re: Changing timing belt, what else should I do? (WiggiE)
I have yet to see one fail on a Honda, nor do want to.
It is a bearing and a wear item. Replace if it's high mileage.
Old May 12, 2003 | 07:49 AM
WiggiE's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC &raquo;</TD></TR><TR><TD CLASS="quote">I have yet to see one fail on a Honda, nor do want to.
It is a bearing and a wear item. Replace if it's high mileage.</TD></TR></TABLE>
I gotcha, cheap insurance. So should I do mine now @ 70k or should I wait till the next timing belt replacement @ 140k?
Old May 12, 2003 | 07:59 AM
IN VTEC's Avatar
Change it at 70k. I really can't justify either way, but you'll have better peace of mind if you change it now, rather than later.
Old May 12, 2003 | 11:04 AM
M-Type's Avatar
if you have the money get some ITR or aftermarket cams while the timing belt is off.
Old May 21, 2003 | 08:28 AM
NVBAM's Avatar
Default Re: Changing timing belt, what else should I do? (M-Type)
Wont putting in new cams require more money to tune it though too?
Old May 21, 2003 | 06:54 PM
stumpyf4's Avatar
Default Re: Changing timing belt, what else should I do? (NVBAM)
do the valve adjustment while you have the valve cover off.
G2_Fella
Aug 3, 2006 11:04 PM
Iomega01
Aug 2, 2005 08:12 PM
zracer240
Aug 1, 2005 10:07 AM
NonovUrbizniz
Nov 15, 2003 02:28 PM
2camsaam
Jul 30, 2003 12:20 PM
