Tenzo R/tociko a good combo?
I recently purchased tokico struts(not blues) and Tenzo R lowering springs,Im not really quite satisfied with the drop since it still shows a bit of wheel gap even though it was lowered 2 inches.Also are camber kits required for a 2inch drop?I know if I go lower than 2" I will need a camber correction kit.What kind of springs would you recommend that drop your car about 2.5 to 3 inches or lower.I was considering coilover kits but I've heard that they are quite stiff.
1) Tenzo springs are not good.
2) Buy coilovers.
3) 3" is too much if you are planning on handling.
4) 2"+ will MOST LIKELY require a camber kit. I know PatrickGSR94 is dropped about 2.25" and didnt need one.
2) Buy coilovers.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FrostWhiteDC4 »</TD></TR><TR><TD CLASS="quote">over 2" in too much IMO. get hr sports with kyb agx</TD></TR></TABLE>
PatrickGSR94 is lowered ~2.5" with his H&R Sports.
https://honda-tech.com/zerothread?id=471971
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WiggiE »</TD></TR><TR><TD CLASS="quote">
https://honda-tech.com/zerothread?id=471971</TD></TR></TABLE>
not sure about that then, hr sports are 1.75/ 1.5 it also depends on your make and model of the car. it could be lower.
kraaaaap
20
Jul 6, 2007 09:14 AM
iheartmyEG
Sep 5, 2006 06:53 PM
98GSRDC2
Suspension & Brakes
May 14, 2006 11:02 PM
