Just took my car out for the first time in the heat...major heatsoak
My car heatsoaked something serverely today. I'm having trouble pinpointing what the cause is.
First off let me say im not proud of it but i have a side mount IC inside the engine bay, just to get the car running so i can move it around in my lot. I know that is the major cause of this, although, I would like to figure out if a few other things are contributing to it.
Right before i took it out, i decided to change from my stock cam to a crane stage II n/a cam that i had in it when i first put the turbo on. I was running 8lbs at the time with the crane cam in it and the turbo pulled hard till my 7k rev limit. At one point last year i swapped the stock cam back in to see if the stock exhaust duration would give me some better spool up.
Well I'm running 12lbs now and i took it out with the crane cam in it to do some testing.
Here's what i noticed:
1 - Its powerband died at 6800, just like it did with the stock cam
2 - It took only 2 blocks off casual driving before i reached full operating temp
3 - The car hesitated on WOT between 5-5500
4 - It was slow as fock
So i took it back to my garage and opened the hood, the engine bay is hot as a heck!! The intercooler is hot to touch, NOT GOOD!!!! So i said eff it, its getting parked till i have the money to finish it right.
My conclusion is that the cam didnt have much to do with the turbo pulling till 7k, rather it was that i was running 8lbs at the time and the turbo wasnt being nearly as taxed as it is running 12lbs. I also think the overlap on the stage II crane cam is not good for a turbo setup and is upping my exhaust temps.
Anyone have any input????
sorry too much to drink this weekend...
please delete, was supposed to be in regular FI forum.
darkblue1998ls
Nov 28, 2005 01:34 PM
BorderM3
May 12, 2003 02:31 PM
Quetzolcotl
Mar 16, 2003 10:04 AM
