need help reognizine ctr piston
Old May 11, 2003 | 11:29 PM
JDM_Risa's Avatar
Default need help reognizine ctr piston
does anyone have links to ctr psiotn like on how to recognize them i am about to purcahse them from a private seller don't want to get scammeda friend
a friend of mine told me it loks like huge moutnains he said i wll know but i know there writing on it....whats inscribe on the pistonhelp will greatly be appreciated
Old May 12, 2003 | 06:36 AM
IN VTEC's Avatar
Default Re: need help reognizine ctr piston (GunMETAL_TEgRa)
PCT on teh dome
25 is they're oversized
Old May 12, 2003 | 06:39 AM
cleggboy's Avatar
http://www.hmotorsonline.com/s...10002
that is a pic of a ctr piston
Old May 12, 2003 | 01:50 PM
JDM_Risa's Avatar
Default Re: (cleggboy)
thanks for the reply so what size of rings do i get standard or oversized how big and so on....thank youagain
Old May 12, 2003 | 01:55 PM
JDM_Risa's Avatar
Default Re: (GunMETAL_TEgRa)
i am putting it in a GSR block..off a 94 integra...
Old May 12, 2003 | 05:02 PM
IN VTEC's Avatar
Use standard sized bore rings with standard sized bore pistons.
Use oversized rings with an oversized piston. Simple as that.
Old May 13, 2003 | 07:12 PM
JDM_Risa's Avatar
Default Re: (IN VTEC)
Type R head
custom port and polish
milled .003 thousandths
resurface valves
skunk2 valve springs
Type R retainer/Type R valves
oem 2 layer GSR gasket
Skunk Stage 2 cams
Type R intake manifold
JG 65mm TB
all the basic bolt ons
will i have any problems with valve clearance after i seen all the "mountainous dome" on the CTR piston i am kinda of scared putting this piston in my new set-up
does anyone have this with stage 2 skunk....how much power did it yeild
Old May 13, 2003 | 07:19 PM
Mr. Softee's Avatar
its tough to say, clay your motor.
Old May 13, 2003 | 07:28 PM
JDM_Risa's Avatar
Default Re: (94goldjungsr)
what do u mean clay your motor down........u mean every spec about it
its got 122kmls.......
i don't know what to say else...
Old May 13, 2003 | 07:44 PM
tegasaurus's Avatar
nice title sam
i want one i feel left out haha
-ryan
Old May 13, 2003 | 08:24 PM
TRuST's Avatar
Claying the motor is basically measuring the distance from the valve to the pistons at TDC.
Jago
Mar 18, 2007 11:11 PM
EgSalad
14
Sep 26, 2006 11:06 AM
inzane
Nov 21, 2005 07:03 AM
vtec69
Nov 21, 2001 06:36 AM
