Ride characteristics between a thick/thin tire profile?
Old May 11, 2003 | 07:33 PM
yellow blur's Avatar
Default Ride characteristics between a thick/thin tire profile?
Can anyone give some ride/wear characteristics with say a thinner sidewall for a 17" rim, or a thicker sidewall?
I'm assuming a bumpier ride with the thinner sidewall and a softer more absorbed, so to say, ride with the thicker sidewall. I was having a converstaion with a friend, and he was saying how suspension components begin to wear out on a thinner sidewall. Before calling him an idiot and jumping to conclusions, I began to think about it and it made some sense but I'm still doubting the validity of it.
Edit: Friend drives a S14 with a blacktop SR20DET swap on springs. That's why I ask for the 17" example.
Comments anyone?
Ed
Old May 11, 2003 | 07:44 PM
.RJ's Avatar
.RJ
Default Re: Ride characteristics between a thick/thin tire profile? (yellow blur)
A tire will act as a spring, and it is undamped. I would think that the wear rate on your suspension components would be closer related to how you use the vehicle than what the tire sidewall height is. However as the level of grip on the tire goes up (non DOT slicks for example) the suspension will take a beating.
Sidewall stiffness should also be taken into consideration as well as sidewall height - Ride on my 205/50/15 Falkens was noticeably harsher than my 195/60/15 all seasons.
Old May 12, 2003 | 05:17 AM
MiraiZ's Avatar
definately a harder ride
Old May 12, 2003 | 08:45 AM
HogNutz's Avatar
also the thinner the tire the more sound on the road it will pick up.......weird but it does
Old May 12, 2003 | 11:54 AM
oryanh's Avatar
Default Re: Ride characteristics between a thick/thin tire profile? (HogNutz)
Your "turn-in" speed will greatly increase with a significantly lower profile tire.
There will be less tirewall to flex when you yank the wheel.
This was the first thing I noticed when going less aspect ratio.
Old May 12, 2003 | 11:59 AM
.RJ's Avatar
.RJ
Default Re: Ride characteristics between a thick/thin tire profile? (oryanh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oryanh &raquo;</TD></TR><TR><TD CLASS="quote">Your "turn-in" speed will greatly increase with a significantly lower profile tire.
This was the first thing I noticed when going less aspect ratio.</TD></TR></TABLE>
when you made this change, did you change tire type/width/compound also?
Old May 12, 2003 | 12:13 PM
oryanh's Avatar
Default Re: Ride characteristics between a thick/thin tire profile? (.RJ)
In my previous ride? no.
Recently, yes.
Old May 12, 2003 | 12:16 PM
.RJ's Avatar
.RJ
I was just wondering since its often hard to find a tire that has the same section width with more than one aspect ratio... changing section width and/or tire compounds makes it hard to get a good comparison for aspect ratio and vehicle performance.
My 205/50/15 falkens turned in better than my 225/45/15 kumho ecsta v700's. While the r-tires are faster, the falkens 'felt' better.
Old May 12, 2003 | 03:33 PM
Thanks for the info guys. I was thinking more towards the wear side of things, like suspension components needing to work more because of less absorbtion by the tires...
Ed
Old May 12, 2003 | 03:49 PM
.RJ's Avatar
.RJ
Unless you're running full non-dot slicks, you really dont have much to worry about
Mangotreemechanic
Oct 12, 2006 07:29 PM
erikiksaz1
Sep 2, 2006 01:52 PM
twobit
Nov 24, 2005 08:50 AM
DarkTeg94
Aug 27, 2004 01:50 PM
