toda spec C and idle..
Old May 11, 2003 | 06:40 PM
TriK's Avatar
Default toda spec C and idle..
sorry my english sucks... :\
we have toda spec C cam in a 2.0 b18c5 at 13.0:1 c/r
but the car have no idle below 2000 rpm.. (camgear at -2ex, 0in)
we will install a standalone in like 2 month...
right now what can i do to have a bit of idle??? we already ajust the screw on the throtle body.. i don't like the idea to play with the gaz cable..
any idea?
Old May 11, 2003 | 06:45 PM
bottlefedb18c1's Avatar
what stand alone are you running with what injectors?
Old May 11, 2003 | 06:54 PM
NSX Bob's Avatar
New User
Default Re: toda spec C and idle.. (TriK)
I would think leaving the cams set at 0,0 would help the idle a little bit until you get a standalone.
Old May 11, 2003 | 07:04 PM
TriK's Avatar
Default Re: toda spec C and idle.. (Type R Bob)
right now we have rc 310 injector
with a p28 special made chip for that.. "very temporary"
Old May 11, 2003 | 09:50 PM
powerfulperformance's Avatar
did you check to see if the throttle cable is on too tight?
Old May 11, 2003 | 10:23 PM
sgT's Avatar
sgT
Default Re: toda spec C and idle.. (powerfulperformance)
no idle with those injectors. get an afc
Or you can put the stockinjectors backin and try again.
Old May 12, 2003 | 04:49 AM
CHEETAH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TriK &raquo;</TD></TR><TR><TD CLASS="quote">sorry my english sucks... :\
any idea? </TD></TR></TABLE>
what fuel pressure ? 310cc is too much fuel at idle. -2 ex doesnt sound like too much overlap, must be too much fuel
greg
J2KWIK
Apr 21, 2004 06:04 AM
EF_LSVtec
12
Jun 28, 2003 05:29 PM
CStyles45
Sep 4, 2002 08:08 AM
TaboR
Apr 9, 2002 12:52 PM
1fastGSR
Dec 26, 2001 04:52 PM
