starting air valve
Old May 11, 2003 | 06:32 PM
k_spek's Avatar
Default starting air valve
This valve is bolted to the front of the intake manifold above the fpr and to the right of the throttle cable bracket. It has a vacuum line coming off it that attaches to a nipple on the intake tube right before the throttle body. I know they only come on usdm h22a1's and h23a1's. Does anyone know what this valve does? Is it only for idling? Does it affect emissions at all?
I have a jdm h22a and I am missing the valve. The referee told me I need this valve to pass visual inspection. It's for my BAR sticker for my jdm swap.
Does anyone know if the starting air valve off an h23a1 will bolt on to an h22? Does it come on the 97+ h22a4's also?
Does anyone know where I can get one or have one they will sell to me. I tried posting this in the classifieds but it moves so fast and this is a prelude specific part, so I figure I'd try in this forum. Thanks guys.
Old May 11, 2003 | 06:35 PM
4bidden's Avatar
Default Re: starting air valve (laugHin22CX)
I would say the H23 one will work since the IMs are basically identical in design. Just go grab one from a junkyard.
Old May 11, 2003 | 10:17 PM
k_spek's Avatar
Default Re: starting air valve (4bidden)
k thanks for the info. I was gonna go try a junkyard really soon. Just wanted to see if anyone had this valve lying around and wanted to get rid of it.
Old May 12, 2003 | 09:51 AM
flyrod's Avatar
It adds some air to the intake manifold until it sees vaccume. i.e. it's supposed to help to let you start the car without touching anything but the key. It has absolutely nothing at all to do with emmisions. Stoopid bureaucrats. I made a cover plate and tossed mine. Might make a difference trying to start it when it's 40 below, but dead weight where I live... I'd say just plug it.
Say, did your JDM engine have cover for the hole? I'll swap you a valve for that cover. I have a couple lying arund in my busted parts/useless junk pile. PM me.
Old Mar 6, 2007 | 12:19 AM
smackdown's Avatar
Default Re: starting air valve (flyrod)
i had jdm h22 and i put the starting air valve from my h23 ... had for three months never had problems but when i romoved it put the block plate back my egine starts easy i would say engine feels so much better than with air S valve
that_boy_sammy
Jan 13, 2013 02:58 AM
KidFrost
Feb 16, 2008 05:08 PM
beanbag
Aug 7, 2007 04:34 AM
Euro2JDM
Nov 15, 2006 03:58 AM
k_spek
May 12, 2003 07:16 AM
