Radiator???
Id guess its the normal crack in the radiator that happens so frequently. its probably just not big enough to leak enough out yet to mess up your temp guage YET. Id suggest finding where its leaking and if its the radiator get it fixed.
Is your radiator the OEM one? If it is, then most likely there is a crack on the plastic top of the radiator. You can try putting some epoxy over the crack, but that's only a temporary solution. Most OEM radiators tend to crack at around 100k miles.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by timmy8151 »</TD></TR><TR><TD CLASS="quote">Is your radiator the OEM one? If it is, then most likely there is a crack on the plastic top of the radiator. You can try putting some epoxy over the crack, but that's only a temporary solution. Most OEM radiators tend to crack at around 100k miles. </TD></TR></TABLE>
Guest
Posts: n/a
yeah its a plastic POS i just put on my apexi last friday and noticed that it was leaking
i have only drove it a little to try to see if that plugger ish worked... it didnt but oh well time to get it fixed. then i get to enjoy the n1
i have only drove it a little to try to see if that plugger ish worked... it didnt but oh well time to get it fixed. then i get to enjoy the n1Thread
Superhatch
24
Sep 20, 2004 10:13 AM
