my turn signal is acting weird...
Old May 11, 2003 | 05:42 PM
crxtreme27's Avatar
Default my turn signal is acting weird...
last nite when i got in my car and turned on my headlights, i noticed that my right turn signal (in the cluster) light stayed on solid.... when i tried to signal right, nothing happened.. my signal just stayed on..... but when i turn off the lights, it signals normal....
what could be wrong??
thanks
Old May 11, 2003 | 05:56 PM
DaDaShT's Avatar
Default Re: my turn signal is acting weird... (crxtreme27)
could be your flasher is going out....is your lights acually flashing or is it just the light on your dash not flashing?
Old May 11, 2003 | 06:18 PM
crxtreme27's Avatar
Default Re: my turn signal is acting weird... (DaDaShT)
well.. the light on the dash stays on (solid) as soon as i turn my parking lights/ headlights on... but the actual turn signals outside the car do not turn on at all...
thanks
Old May 11, 2003 | 06:48 PM
bottlefedb18c1's Avatar
check the grounds by the light it happened to me on my mustang
Old May 11, 2003 | 08:26 PM
sackdz's Avatar
Default Re: (bottlefedb18c1)
Same thing with my car right now. Happened after I smacked a tire wall at the track. It's a broken ground somewhere I'm sure of it, just too lazy to track it down.
Old May 11, 2003 | 09:30 PM
crxtreme27's Avatar
Default Re: (sackdz)
ok, tomorrow i will check out all the grounds i can think of.. thanks for the info guys
Old May 15, 2003 | 05:19 PM
crxtreme27's Avatar
Where are these wires located??? I changed the flasher but its fine.. i need to find fix this problem because i cant signal right...
thanks
patrickstar
Apr 23, 2009 10:28 PM
EkREV
Sep 19, 2005 09:01 PM
crawdad689
Apr 12, 2004 08:42 PM
crawdad689
Feb 9, 2004 04:55 PM
