Mounting ECU near passenger foot area... fiberglass?
Old May 11, 2003 | 04:32 PM
Tweakmeister's Avatar
Default Mounting ECU near passenger foot area... fiberglass?
Hopefully someone can help me out here.
Basically the ECU won't fit under the corner kicker panel with the huge harness I want to put on it. I'd like to lay the ECU flat against the angled foot area instead. In doing this however, the wires and ECU are now "exposed" unless I can find some way to cover them.
I'm looking for suggestions on doing this. Would fiberglass work best, or just lay a little padding on there and put the carpeting back on top? What do you think, thanks!
Old May 12, 2003 | 09:23 AM
EK22Tim's Avatar
Default Re: Mounting ECU near passenger foot area... fiberglass? (Tweakmeister)
Well, truthfully I donno if I'd just trust padding and carpet. When you have passengers, and they have wet feet, there is a possibility of getting your wires/ecm wet etc. which will lead to corrosion and nastiness. I suggest that fiberglas idea. that's pretty cool. jsut take a mold of your current piece and make it a bit deeper.
Old May 13, 2003 | 01:52 PM
Default Re: Mounting ECU near passenger foot area... fiberglass? (EK22Tim)
cool thanks for the input.
we'll see how it turns out...I'll probabl just pad it for now.
Old May 13, 2003 | 03:23 PM
B Speed's Avatar
I'm not sure if the wires will reach, but how about mounting in the glovebox?
Old May 13, 2003 | 04:33 PM
hanson said's Avatar
Default Re: Mounting ECU near passenger foot area... fiberglass? (B Speed)
use sheet metal instead. i'd be afraid of someone accidentally kicking a hole in the fiberglass.
Old May 14, 2003 | 07:01 PM
Default Re: Mounting ECU near passenger foot area... fiberglass? (hanson said)
hmm sheet metal might work.
I've got some aluminum flashing from Home Depot...I was going to try and bend it but dismissed the idea.
I'll look into it again.
jeremiah87
Jul 15, 2007 01:04 PM
huge230
Sep 3, 2005 08:03 AM
Simple
37
Nov 7, 2004 07:59 PM
Jonathan_ED3
Dec 23, 2003 11:23 PM
sshaikh01
26
Mar 28, 2003 07:49 PM
