AF gauge not working?
Old May 11, 2003 | 02:26 PM
bumpin_bass's Avatar
Default AF gauge not working?
I just installed an Autometer A/F gauge, but it is not turning on. I hooked black wire to ground, red wire to 12V ignition, and purple wire to the O2 wire off of the ECU. The gauge is not doing anything at all. All of my connections are good. Any ideas would be greatly appreciated. Thanks
Old May 11, 2003 | 02:37 PM
dfoxengr's Avatar
Default Re: AF gauge not working? (bumpin_bass)
red to constant switched power?
Old May 11, 2003 | 02:41 PM
non-VTEC's Avatar
faulty guage perhaps?
send it back.........
Old May 11, 2003 | 03:13 PM
Default Re: AF gauge not working? (non-VTEC)
Yeah I guess it must be faulty. Back to Summit.
Old May 11, 2003 | 03:19 PM
7PSI CRX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bumpin_bass &raquo;</TD></TR><TR><TD CLASS="quote">and purple wire to the O2 wire off of the ECU.</TD></TR></TABLE>
I'll bet you tapped the wrong wire.
Old May 11, 2003 | 03:21 PM
Default Re: AF gauge not working? (7PSI CRX)
I tapped the PO2 wire C18 ECU is the P30. With a voltmeter this wire puts out readings from around .2 to 1 volt which is correct.
Old May 11, 2003 | 03:24 PM
dfoxengr's Avatar
should be a white wire
Old May 11, 2003 | 03:32 PM
Default Re: AF gauge not working? (hybridvteceg)
yeah it is a solid white wire
Old May 11, 2003 | 04:36 PM
Blaze45's Avatar
Brrraaaap!
That gauge is not accurate at all. Sell it.
Blaze
Old May 11, 2003 | 05:47 PM
sspikey's Avatar
Default Re: AF gauge not working? (Blaze45)
save your money for soemthign that doesnt entertain the girls
http://www.techedge.com
or http://www.techedge.co.uk
or http://www.diy-wb.com
one of those should rule.
Old May 11, 2003 | 07:35 PM
VTECorona's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blaze45 &raquo;</TD></TR><TR><TD CLASS="quote">That gauge is not accurate at all. Sell it.
Blaze</TD></TR></TABLE>
Yes, it is only a light show.
SpeedMonkeyRacing
Oct 20, 2004 01:33 PM
LostCRX
Mar 8, 2004 12:58 PM
RAWB
Feb 6, 2002 10:27 PM
