fog lights as turn signals
Old May 11, 2003 | 10:17 AM
xsuperdanx's Avatar
Default fog lights as turn signals
yea... does anybody know how to wire up fog lights to flash in place of turn signals?
Old May 11, 2003 | 12:29 PM
NonovUrbizniz's Avatar
Loved
Default Re: fog lights as turn signals (xsuperdanx)
use a relay with power from the battery a solid ground and then tap off of your blinker wires for the trigger power and ground...
P.S. WHY GOD WHY.
Old May 11, 2003 | 02:39 PM
dfoxengr's Avatar
Default Re: fog lights as turn signals (NonovUrbizniz)
or just connect power to turn signale power and ground to signal ground...
Old May 11, 2003 | 02:56 PM
Loved
Default Re: fog lights as turn signals (hybridvteceg)
I think running it independent so you can FUSE the power properly would be a better idea...
You'll just keep popping fuses if you wire it directly to the corners.
Old May 11, 2003 | 02:59 PM
dfoxengr's Avatar
so then put an inline fuse in, dont need anything extra
Old May 11, 2003 | 04:31 PM
Loved
I would also worry about the MUCH higher draw on the wire meant only to carry so much amperage...
if the guage is too small and you fuse it so it doesn't blow you could melt the wires and risk starting a fire...
If you're going to do something as silly as wiring fog lights to be blinkers at least do it right/safely.
SoL_ger
Mar 14, 2010 11:07 AM
tweek_boii
Jun 22, 2009 10:43 PM
cvcrcer
Mar 31, 2005 06:04 PM
ScottEK
Audio / Security / Video
Jul 24, 2003 08:59 PM
