what rods do i need for my ctr pistons to work in my b16a1 crx
Old May 11, 2003 | 03:05 AM
b16powwer's Avatar
Default what rods do i need for my ctr pistons to work in my b16a1 crx
heres the deal, i got me a set of new stock size ctr pistons w/rings, my stock b16a1 rods wont work, unless i take them to a shop to cut a little off the inside of the piston so they can be pressed in. what is another rod that will work w/out doing any work on the piston or rod. do they make b16b rods, and are they better then other aftermarket rods. i need to get my car up and running agian. can someone please help.
thanks all at honda-tech
Old May 11, 2003 | 04:31 AM
bryant's Avatar
Default Re: what rods do i need for my ctr pistons to work in my b16a1 crx (b16powwer)
http://www.ff-squad.com/pistons.htm
check near the bottom.
Old May 11, 2003 | 06:46 AM
CRXBart's Avatar
Just mill 1mm off each side of the rod end. I did and it works great. I've been running my motor for two years with this setup and have had no problems. If you think about it in Japan in the b16bs thats probally the way it was.
Master23
Apr 21, 2006 03:18 PM
na_lseg
Sep 1, 2005 01:53 PM
vtecmonster001
Jan 13, 2005 08:12 AM
JDM978
Oct 30, 2004 05:48 PM
b16powwer
May 11, 2003 01:17 PM
