new personal best on street tires!
Old May 10, 2003 | 08:18 PM
Hispeed's Avatar
Default new personal best on street tires!
Made the trip to the track this past thursday for sport compact night. Met up with a few honda-tech members and had a blast on street tires! I am using the bfg drag radials 205/50/15. I forgot how hard it was to drag race on radials! My low boost is set to 12 psi (spring in wg) and high boost is 20 psi. I started by just running a low boost the whole way. Netted me a 12.78 @ 123 w/ a 2.2 60'. Next run a missed shifted and aborted the run. 3rd run I heated the tires up and did a little better. 12. 48 @126 w/ a 2.1 60'. I did hit high boost in middle of 3rd. 4th run blew an intercooler pipe off run was aborted. 5th run I heated the tires up and concentrated really hard on the 1st 2 gears. I launched at 6000 trying to feather the clutch as much as possible (which is almost impossible w/ a twin disk) got out of the hole and feathered the gas as much trying to control the tire spin at low boost, shifted to 2nd gear still trying to controll tire spin hit the high boost botton as soon as tire spin was under control at the top of 2nd and again began to fight for control. Shifted into 3rd flawlessly and continued to feather the gas until the middle of the gear and then it was a go. Hung on tight and shifted into 4th w/o a hitch. Came around picked up my slip and got a new personal best:
12.06 @ 127 mph w/ 2.01 60'
I think TURBODANDEE has it on film if he cares to post it!
In case you are wondering we tried the slicks out and only got a 1 descent pass out of them. Blowing boost pipes plauged me the rest of the night. It has now been taken care of I hope (crossing fingers) the pipes now have a bead on! But unfortunetly I sold my slicks this morning so it will be about another month before I make it out to the track w/ 24.5" On the brighter side of things.. The one descent pass w/ the slicks was a 11.42 @ 132.5 mph @20 psi (shortshifted into 3rd and lost too much boost). I like to see progress and more so I like that mph
Old May 10, 2003 | 09:02 PM
yimmy's Avatar
Default Re: new personal best on street tires! (GSRev)
Nice times What boost controller are you using.
Old May 10, 2003 | 09:06 PM
Arturbo's Avatar
Better than steak
25 Year Member
Alex, I was trying to call you today because word got back to me that you ran 11.4 on street tires! But anyhow, still a good time..
art
Old May 10, 2003 | 09:10 PM
Hispeed's Avatar
Default Re: new personal best on street tires! (yimmy)
greddy profec-b
Old May 10, 2003 | 10:31 PM
93LSivic's Avatar
Wow
Nice times man!
What clutch would that be?
Old May 10, 2003 | 11:33 PM
rOby's Avatar
Default Re: new personal best on street tires! (93LSivic)
cm twin disk
nice goin alex
Old May 10, 2003 | 11:45 PM
boostaholic's Avatar
Default Re: new personal best on street tires! (rOby)
Sweet times Alex! You still coming down to LA for that race?
Old May 11, 2003 | 01:17 AM
TurboDANDEE's Avatar
Default Re: new personal best on street tires! (boostaholic)
Yes, i have proof... if someone would care enough to host some pics
That was a bad *** night, lots of cars represented and met a few people. i finally saw alex's car up close and it is very clean and well put together and also his friend Mario, very cool group. Hope to come back again with stronger axles and a cage
Old May 11, 2003 | 01:25 AM
GOLDBERG's Avatar
Default Re: new personal best on street tires! (TurboDANDEE)
how much power is that car making??and what weight??great times
Old May 11, 2003 | 01:38 AM
Boost2NA's Avatar
Damn man 12.06 on 205/50/15. Thats freaking awesome. If you dont mind could you post your set up.
Old May 11, 2003 | 04:38 AM
turbo Si's Avatar
Default Re: new personal best on street tires! (Boosted99Si)
The welded beads will work out great for you Alex. Atleast they did for me. How much you get for the Lenso's with slicks?
Old May 11, 2003 | 04:42 AM
DragEG6 FI's Avatar
Great E.T. and damn good mph...yeah id also like to know the power and weight of that beast.
What kind of 60ft on slicks?
Old May 11, 2003 | 04:47 AM
turbo Si's Avatar
Default Re: new personal best on street tires! (Bsmoak)
I think it weighs around 2300lb's and making around 450whp right now.
Old May 11, 2003 | 05:51 AM
Turbo92Si's Avatar
Default Re: new personal best on street tires! (turbo Si)
good times
Old May 11, 2003 | 06:02 AM
Hispeed's Avatar
my setup basically consist of the following:
big turbo
built gsr block
upgraded valve train
hybrid tranny
speedpro sequential
car weighs 2390 with driver. Used to be lighter but the cage added to it. For complete details of my car.. click on attitude racing on my sig. The car initially dyno'd at 438 hp @21psi, but I was having ignition problems. They have since gone away with the digital 6+. I should be back on the dyno before the end of the month 2 prepare for IMPORT FACE OFF 3
Old May 11, 2003 | 12:22 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRev &raquo;</TD></TR><TR><TD CLASS="quote">I should be back on the dyno before the end of the month 2 prepare for IMPORT FACE OFF 3 </TD></TR></TABLE>
Hey, where and when is this?
Oh ya, can someone host some pics for me?
Old May 11, 2003 | 12:24 PM
QCKGSR's Avatar
Default Re: new personal best on street tires! (Turbo92Si)
great times
Old May 11, 2003 | 01:32 PM
Old May 11, 2003 | 01:36 PM
thanx Chris for hosting
Old May 11, 2003 | 01:38 PM
GOLDBERG's Avatar
Default Re: new personal best on street tires! (QCKGSR)
are you using gear dependant boost control??? or full boost from 1st on up??thanks this is seriously making me change my mind about going all motor
Old May 11, 2003 | 01:39 PM
TeStUdO's Avatar
what intake mani is that? it looks like a stock gsr wrapped in a trashbag
Old May 11, 2003 | 01:40 PM
Default Re: new personal best on street tires! (GOLDBERG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GOLDBERG &raquo;</TD></TR><TR><TD CLASS="quote">this is seriously making me change my mind about going all motor </TD></TR></TABLE>
Hahaha word
Old May 11, 2003 | 02:09 PM
GOLDBERG's Avatar
oooohh i see an EK can anyone gimme details of the ek hatch on the left that ran the 12.6?
Old May 11, 2003 | 02:17 PM
TurboSedan's Avatar
New User
Great job, I love full interior street driven cars that run those kinds of times. I aspire to get into the 12's with my daily driven EK sedan. We're working on 13's at the moment. One step at a time.
Old May 11, 2003 | 02:26 PM
SikofFalln's Avatar
Default Re: new personal best on street tires! (TurboSedan)
Your car is waht I want mine to be. Good time man
