my stick VS tig welding
I have about 30 minutes of welding experience. I turned the welder all the way up in stick mode to blow a hold in the metal and placed the bolt in there. Then I used different power levels to see how to best lay a bead. I then tried the tig torch, and that made a real fine arc that didn't go through the metal as you can see the two pipep joined.
practice laying your stick welds on something else other than what matters ;-)
also watching someone helps big time. in about 2 hrs practice time with my brother, i was laying horizontal welds pretty much identical to his, and he's a cert. welder (many different styles etc.) all except for vertical and overhead of course. heh.
Practice makes perfect. what kind of rod, and what size are you trying to weld with?
I dont know what size rod, I bought the welder used and it came with some stuff. The rods have a white dot on the end of them and looked 1/16 inch. The tig welding I didn't use any filler, I just melted it together. I think when I make the downpipe, I'll have more practice tigging and get a nice roll of dimes.
were you using sheilding gas cause ive gotten better welds with a flux core welder haha, take some time it will get better and do some reading on it then go out and practice
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Xscream »</TD></TR><TR><TD CLASS="quote">If it holds, who gives a ****!
I must say if you were able to strike a arc within the first 30 minutes you are not doing that bad.</TD></TR></TABLE>what he said, go before show
LMFAO
Looks liek my 1st year in Metal Shop class long ago. Takes a while to lay down some good beads but hey u learn as u go right. Just as long as it wont leak and works good, then your good to go.
Did u use an ARC or TIG welder.
I used the arc on the o2 bung, and the tig on the seam connecting the two 2 1/4 pipe.
I might be imagining things, but I think my wideband reads about .2 leaner since I had to use a bolt insted of a bung. I think I'm going to cut it off next week and weld in a real bung, I'm going to tig it this time.
I'll probably drop a pound off my car too.
LOL
More like 2 lbs off. Practice on a piece of square metal or something laying beads on top of eachother. Thats how i leanred to lay down Prefect beads. The Tig welder is a bit hard for me for some reason. On the ARC welder, i was pretty good. Post some pics when u try it again.
unusual71
18
Apr 18, 2011 11:13 AM
hondaapi
Dec 8, 2005 09:31 AM
