clunking sound and shocks?
Old May 10, 2003 | 06:38 PM
kupras's Avatar
Default clunking sound and shocks?
Im getting this clunking noise every once and a while coming from the front right and left side....near the wheels. Could that be a sign of blown shocks??
Old May 10, 2003 | 07:20 PM
Gee3's Avatar
From: Formerly of SF moved to DFW and now back in SF, CA, USA
Default Re: clunking sound and shocks? (kupras)
I believe so. or maybe a worn bushing(s)?
Old May 10, 2003 | 09:31 PM
kupras's Avatar
it happens only when im going at slow speeds. My friend was mentioning that it could be the axles but what would that sound like.
Old May 11, 2003 | 09:02 AM
VTECorona's Avatar
Default Re: (kupras)
When you tightened up your bolts while installing did you have the shock compressed under the cars weight? Jack it up from right around where the bottom end of the shock is mounted and jack it up until you see the car to start lifting off of the jack stands and then torque the nuts. I did that and it fixed my problem.
Old May 11, 2003 | 11:00 AM
The-LS's Avatar
Default Re: (97RedTegGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97RedTegGSR &raquo;</TD></TR><TR><TD CLASS="quote">When you tightened up your bolts while installing did you have the shock compressed under the cars weight? Jack it up from right around where the bottom end of the shock is mounted and jack it up until you see the car to start lifting off of the jack stands and then torque the nuts. I did that and it fixed my problem.</TD></TR></TABLE>
which nuts are you refering to?
Old May 11, 2003 | 02:51 PM
VTECorona's Avatar
Default Re: (Black-LS)
The bolt that goes through the fork part of the damper fork.
puertoroc7976
Suspension & Brakes
Mar 14, 2007 08:54 PM
The-Kid
Mar 11, 2007 08:55 PM
Mordeki
Suspension & Brakes
Oct 25, 2005 01:31 PM
blackeg
Feb 13, 2005 07:17 PM
