which rear lower tie bars w/ ITR sway...??
hey I have a ITR rear sway w/ BSQ's kit.... which rear lower tie bars work with it??
I know the BENEN bar works, which other bars do I have to choose from??
thanks alot!!
thanks alot!!
search, its out there...
https://honda-tech.com/zerothread?id=458999
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BSQ »</TD></TR><TR><TD CLASS="quote">The following rear lower tie bars work with the Type-R rear swaybar (when used with my BSQ mounting kit) with no further modifications: Spoon, Comptech, JIC Magic and Benen. But there has been a few people that have recently stated that the Benen bar would not fit without some additional spacers. So I'm not sure if Benen has changed their tie bar recently that prevents it from being a direct bolt-on.
Other rear lower tie bars such as the Neuspeed, Skunk2, etc. will work with the Type-R rear swaybar, but you will need a two 1/2" LCA bolts and a two 1/2" spacers which will prevent the tie bar from contacting the swaybar.</TD></TR></TABLE>
i know BSQ mentioned spoon,comptech, and benen but are there ANY others that work without any additional pieces or modification?
i would be interested to know as well. As pleased as i am with the bsq kit, the comptech tie bar that comes with teh sway/tie combo is probably the most appealing one at this point. Too bad its so damn expensive.
EDIT: hey sergio.. so did you order ur bsq kit?
the spoon bar uses brackets to connect to the LCA bolts, then the bar attaches to the brackets with nothing but nuts and bolts. Seems like a very flimsy mounting setup to me. I prefer a solid bar with no brackets.
hey sergio... glad to hear that u remembered to order it. hehe... u must be hella excited. Oh and a word of warning... bangin on that bolt to get the nut off while under the car is gonna be HELLA LOUD. hahah.... i thought i went deaf... ask scott or dennis hahaha...
Carpediem291
Feb 1, 2004 04:13 PM
EricUSC
Nov 5, 2003 09:09 AM
whiteGSR
Aug 14, 2002 01:00 AM
(CAN'T WAIT!!)
