what happened to my engine?
Old May 10, 2003 | 05:21 PM
Artful Dodger's Avatar
Default what happened to my engine?
I just put a 95 d16z6 into my 89 ef, replacing the d15b2 motor. I bought the motor, tranny, mounts, axles, and ecu off someone. I used blown90hatch's ecu conversion harness. I had everthing wired up except vtec. The motor sounded fine and everthing seemed to be working right except for a ticking which got faster as the revs went up. I drove the car a good 20 miles and was pulling out of a gas station; in first gear at around 3-4 k there was a loud thunk noise and the engine cut out and wouldn't start again. The starter sounds fine, the engine just won't start. There are no leaks and no damage I can see. Any ideas on what could have happened? Did the guys sell me a crappy motor? Any help is much appreciated.
Old May 10, 2003 | 05:24 PM
litlekikr's Avatar
Default Re: what happened to my engine? (Artful Dodger)
It was just a clunk? No banging or knocking or anything? Pull the pan, maybe something did break and you just can't see it. Is there metal onthe dipstick? All your connections good?
Old May 10, 2003 | 06:28 PM
Stupid Ass's Avatar
Default Re: what happened to my engine? (litlekikr)
Sounds like you threw a rod or had a valve problem...
Old May 10, 2003 | 07:36 PM
Timmah!!'s Avatar
Default Re: what happened to my engine? (MooreVTEC)
Sound like you may have spun a bearing. Check you oil for metal flakes.
Old May 10, 2003 | 07:49 PM
FourthGenHatch's Avatar
Default Re: what happened to my engine? (azroth)
Sounds like the ticking might have been messed up timing, perhaps the thunk was pistons smashing into valves.
Old May 11, 2003 | 11:13 AM
Pengo's Avatar
Default Re: what happened to my engine? (FourthGenHatch)
bump
Old May 11, 2003 | 11:30 AM
DiPPeD iN miLk Ej CoUpE's Avatar
Default Re: what happened to my engine? (Pengo)
should check your spark plugs an timing the tapping could be becuse of the spark plugs anmight also be why the car won't start up
Old May 12, 2003 | 04:49 PM
Default Re: what happened to my engine? (TooSlowTogoEF)
no metal on dipstick, haven't had time to really look into it. thanks for your responses, I'll let you know how it turns out.
EG-SIXV-TEC
Oct 9, 2014 02:19 PM
dirtmcgirt79
Sep 19, 2008 06:27 AM
keepitngga1
Jun 3, 2008 07:02 PM
95lsinteg
Feb 7, 2004 12:08 AM
Roadrnnr
Sep 5, 2001 05:19 PM
